Hi Mark, thanks for your suggestions. I will give a final try during our maintenance days.
On 7/14/20, 8:03 AM, "Mark Rivers" <[email protected]> wrote:
Hi Yong,
> 2) I tried Mark Engbretson’s suggestion by putting an old slower speed hub in between our upgraded network hardware and this older device. In my case, the system becomes even slower;
As I recall you said that it got slower when your network infrastructure was recently upgraded. That suggests the problem could actually be related to the network.
Here are 2 things I would try:
1) Remove the network infrastructure from the setup completely for testing. Plug the E5810 LAN/GPIB Gateway directly into a dedicated NIC.
2) Use tcpdump or wireshark to capture the traffic between the IOC and the Gateway both with the dedicated NIC and with the normal network configuration.
- Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Hu, Yong via Tech-talk
- RE: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Mark Rivers via Tech-talk
- Re: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Hu, Yong via Tech-talk
- Re: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Mark Rivers via Tech-talk
asyn R4-40 available Mark Rivers via Tech-talk
<2020>
2025
2026
Re: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Michael Davidsaver via Tech-talk
<2020>
2025
2026
