1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: TCP to LabVIEW TCP VI using Stream Device.
To: Daniel Cuneo <[email protected]>, Eric Norum via Tech-talk <[email protected]>
Date: Mon, 20 Jul 2020 22:41:00 +0000
Hi Daniel,
Add these two lines in your startup script or type them in the EPICS shell:
asynSetTraceMask("your-asyn-port",-1,0xff)
asynSetTraceIOMask("your-asyn-port ",-1,0xff)
And you will see what is really going on. Post more debugging messages so that other people probably can help you figure out the issue.
Good luck!
Yong
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: Daniel Cuneo <[email protected]>
Date: Monday, July 20, 2020 at 6:08 PM
Subject: TCP to LabVIEW TCP VI using Stream Device.
Hello all,
My co-worker has setup a TCP virtual interface in LabVIEW, that allows me to send commands
as strings of text, and get replies with data.
Testing in a Linux shell using netcat (nc on CentOS 7) works well.
echo "foobar\r" | nc -h hex.dump labview-host.foo.bar
However, when I attempt to use Stream / Asyn, I get only timeouts.
Stream and asynOctetWriteRead()  both timeout.
One would usually suspect that the line terminators are incorrect. To test line terminators, I turned on the netcat hexdump and can see both a CR and LF (0xD 0xA) being sent in a working netcat test. I put both in my stream protocol file and hard coded when using asynOctetWriteRead.
I'm beginning to wonder if there's a protocol difference between what netcat does and what a generic TCP connection does.
Does anyone have advice on what else I can try to tease out the problem ?
Cheers and TIA !
dpc
Daniel Cuneo
ALS Accelerator Controls
BLD 46-172G
desk: 510-486-5439
cell:   415-871-1909
Re: TCP to LabVIEW TCP VI using Stream Device. Mark Rivers via Tech-talk
TCP to LabVIEW TCP VI using Stream Device. Daniel Cuneo via Tech-talk
Prev: Re: [EXTERNAL] caget for base7 records Hartman, Steven via Tech-talk
Next: Re: TCP to LabVIEW TCP VI using Stream Device. Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: TCP to LabVIEW TCP VI using Stream Device. Daniel Cuneo via Tech-talk
