1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] caget for base7 records
From: "Hartman, Steven via Tech-talk" <[email protected]>
To: Sandeep Kumar Malu - UKRI STFC <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 20 Jul 2020 22:25:22 +0000
> On Jul 20, 2020, at 1:41 PM, Sandeep Kumar Malu - UKRI STFC via Tech-talk <[email protected]> wrote:
> I wish to use channel access method on client side to fetch  V4 Scalar PVRecords.
Is there a reason you cannot use pvAccess on the client side (e.g. pvget instead of caget)? If so, is there a reason you chose to use pvDatabase on the server side?
Steven Hartman
[email protected]
RE: [EXTERNAL] caget for base7 records Sandeep Kumar Malu - UKRI STFC via Tech-talk
Re: caget for base7 records Johnson, Andrew N. via Tech-talk
RE: caget for base7 records Sandeep Kumar Malu - UKRI STFC via Tech-talk
Prev: TCP to LabVIEW TCP VI using Stream Device. Daniel Cuneo via Tech-talk
Next: Re: TCP to LabVIEW TCP VI using Stream Device. Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: caget for base7 records Johnson, Andrew N. via Tech-talk
Next: RE: [EXTERNAL] caget for base7 records Sandeep Kumar Malu - UKRI STFC via Tech-talk
