Subject: TCP to LabVIEW TCP VI using Stream Device.
From: Daniel Cuneo via Tech-talk <[email protected]>
To: Eric Norum via Tech-talk <[email protected]>
Date: Mon, 20 Jul 2020 15:06:43 -0700
Hello all,
My co-worker has setup a TCP virtual interface in LabVIEW, that allows me to send commands
as strings of text, and get replies with data.
Testing in a Linux shell using netcat (nc on CentOS 7) works well.
echo "foobar\r" | nc -h hex.dump labview-host.foo.bar
However, when I attempt to use Stream / Asyn, I get only timeouts.
Stream and asynOctetWriteRead()  both timeout.
One would usually suspect that the line terminators are incorrect. To test line terminators, I turned on the netcat hexdump and can see both a CR and LF (0xD 0xA) being sent in a working netcat test. I put both in my stream protocol file and hard coded when using asynOctetWriteRead.
I'm beginning to wonder if there's a protocol difference between what netcat does and what a generic TCP connection does.
Does anyone have advice on what else I can try to tease out the problem ?
Cheers and TIA !
dpc
Daniel Cuneo
ALS Accelerator Controls
BLD 46-172G
desk: 510-486-5439
cell:   415-871-1909
Re: TCP to LabVIEW TCP VI using Stream Device. Hu, Yong via Tech-talk
Prev: Re: caget for base7 records Johnson, Andrew N. via Tech-talk
Next: Re: [EXTERNAL] caget for base7 records Hartman, Steven via Tech-talk
Prev: RE: [EXTERNAL] caget for base7 records Sandeep Kumar Malu - UKRI STFC via Tech-talk
Next: Re: TCP to LabVIEW TCP VI using Stream Device. Hu, Yong via Tech-talk
