Subject: RE: [EXTERNAL] caget for base7 records
From: Sandeep Kumar Malu - UKRI STFC via Tech-talk <[email protected]>
To: "Hartman, Steven" <[email protected]>, "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 21 Jul 2020 07:02:35 +0000
Hi Andrew & Steven
I thought the same to use pvapy & pcaspy to do the mapping. Thank you for the suggestion.
As of now, we are running V4 IOC as a trial & will use pvAccess on the client side too.
Many Thanks
Sandeep
-----Original Message-----
Sent: Tuesday, July 21, 2020 3:55 AM
To: Malu, Sandeep Kumar (-,RAL,CLF) <[email protected]>
Subject: Re: [EXTERNAL] caget for base7 records
> On Jul 20, 2020, at 1:41 PM, Sandeep Kumar Malu - UKRI STFC via Tech-talk <[email protected]> wrote:
> I wish to use channel access method on client side to fetch  V4 Scalar PVRecords.
Is there a reason you cannot use pvAccess on the client side (e.g. pvget instead of caget)? If so, is there a reason you chose to use pvDatabase on the server side?
Steven Hartman
[email protected]
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
caget for base7 records Sandeep Kumar Malu - UKRI STFC via Tech-talk
Re: caget for base7 records Johnson, Andrew N. via Tech-talk
RE: caget for base7 records Sandeep Kumar Malu - UKRI STFC via Tech-talk
Re: [EXTERNAL] caget for base7 records Hartman, Steven via Tech-talk
Prev: Re: TCP to LabVIEW TCP VI using Stream Device. Mark Rivers via Tech-talk
Next: Re: RE: SteamDevice 2.8.x build on Windows issue 吴煊 via Tech-talk
Prev: Re: [EXTERNAL] caget for base7 records Hartman, Steven via Tech-talk
Next: TCP to LabVIEW TCP VI using Stream Device. Daniel Cuneo via Tech-talk
