1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Changing Asyn Port Driver paramList dynamically
From: "Paduan Donadio, Marcio via Tech-talk" <[email protected]>
Date: Thu, 23 Jul 2020 03:16:11 +0000
Hello.
I have this class inheritance scenario:
asynPortDriver <- fatherClass <- childClass
fatherClass constructor is calling asynPortDriver constructor, informing the number of elements of paramList as well as masks for interfaces used.
I’d like childClass to add more parameters to paramList after fatherClass already created this list and, eventually, add interfaces to the Asyn mask.
Is it possible?
Thank you,
Márcio Paduan Donadio
Control Systems Engineer - SLAC
Re: Changing Asyn Port Driver paramList dynamically Lucas Russo via Tech-talk
Prev: Re: Changing ioc logging. Should I use a modified iocLogServer? Johnson, Andrew N. via Tech-talk
Next: AW: database method to copy string to char waveform Malte Gotz via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: Changing Asyn Port Driver paramList dynamically Lucas Russo via Tech-talk
