1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: AW: database method to copy string to char waveform
To: "EPICS tech-talk" <[email protected]>
Date: Thu, 23 Jul 2020 06:47:04 +0000
Title: AW: database method to copy string to char waveform
Thank you Mark, Ralph and Andrew,
the lso record works perfectly! I wasn't aware it existed in 3.15.
I couldn't get Marks's suggestion to use
field(OUT,"$(X)netCDF1:FileName.VAL$ CA")
in the scalout to work, but didn't try very hard, because the lso record does exactly what I need.
Cheers
Malte
-----Ursprüngliche Nachricht-----
Von: Johnson, Andrew N. via Tech-talk <[email protected]>
Gesendet: Mittwoch 22 Juli 2020 17:35
An: EPICS tech-talk <[email protected]>
Betreff: Re: database method to copy string to char waveform
You can also use a long string output (lso) record to copy a string into a waveform or vice versa. This works for me, and will similarly require 3.15 or later:
record(stringout, "so") {
  field(VAL, "This is another string")
record(waveform, "wf") {
  field(NELM, 100)
  field(FTVL, CHAR)
record(lso, "xerox") {
  field(DOL, "so")
  field(OMSL, "closed_loop")
  field(OUT, "wf")
You can swap the DOL and OUT links to copy in the other direction.
- Andrew
On Jul 22, 2020, at 9:19 AM, Ralph Lange via Tech-talk <[email protected]> wrote:
Hi Malte,
Using current 3.15 or EPICS 7, this database:
record (waveform, "wf") {
  field(NELM, "100")
  field(FTVL, "CHAR")
  field(INP, "so.VAL$")
record (stringout, "so") {
  field(VAL, "this is a string")
does that job for me. Or did I get the problem wrong?
Cheers,
~Ralph
Complexity comes for free, simplicity you have to work for.
Prev: Changing Asyn Port Driver paramList dynamically Paduan Donadio, Marcio via Tech-talk
Next: How to check IOC connection Jong Woo Kim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Changing Asyn Port Driver paramList dynamically Lucas Russo via Tech-talk
