Subject: Re: Changing Asyn Port Driver paramList dynamically
From: Lucas Russo via Tech-talk <[email protected]>
To: "Paduan Donadio, Marcio" <[email protected]>
Date: Fri, 24 Jul 2020 13:21:47 -0300
Hi Marcio,
From Asyn version 4-31 onwards you don't need to specify the number of parameters in advance (see https://epics-modules.github.io/master/asyn/R4-31/RELEASE_NOTES.html). You can just use createParam() and the c++ std::vector will handle this for you. So, in your child class I believe you can just call createParam() as usual. You just need to call the father class method if the parameter ID does not belong to your class.
Regarding specifying interfaces/masks I'm not sure if you can modify this after the father class has already initialized. Of course you can always pass these interface/interrupt mask parameters via the constructor, but I think that's not what you want.
You can also take a look at the QuadEM module that does more or less what you want, apparently: https://github.com/epics-modules/quadEM/tree/master/quadEMApp/src
drvQuadEM would be your father class and drvTetrAMM, drvNSLS_EM, etc would be your child classes.
Hope this helps,
Cheers,
Lucas
On Thu, Jul 23, 2020 at 12:16 AM Paduan Donadio, Marcio via Tech-talk <[email protected]> wrote:
Hello.
I have this class inheritance scenario:
asynPortDriver <- fatherClass <- childClass
fatherClass constructor is calling asynPortDriver constructor, informing the number of elements of paramList as well as masks for interfaces used.
I’d like childClass to add more parameters to paramList after fatherClass already created this list and, eventually, add interfaces to the Asyn mask.
Is it possible?
Thank you,
Márcio Paduan Donadio
Control Systems Engineer - SLAC
Re: Changing Asyn Port Driver paramList dynamically Paduan Donadio, Marcio via Tech-talk
Prev: RE: ADProsilica crashing on RHEL7 3.10.0-1127 Pearson, Matthew R. via Tech-talk
Next: Re: Changing Asyn Port Driver paramList dynamically Paduan Donadio, Marcio via Tech-talk
Prev: Changing Asyn Port Driver paramList dynamically Paduan Donadio, Marcio via Tech-talk
