Subject: Re: Adding a PV to archiver appl, missing something...
From: astrid morreale via Tech-talk <[email protected]>
To: "Hu, Yong" <[email protected]>
Date: Fri, 24 Jul 2020 17:26:09 -0600
Thanks Yong, I took a look at the https://epics.anl.gov/tech-talk/2017/msg00705.php thread and checked the various hints, unfortunately I do think what is suggested in those threads is the problem (?).
My PV shows "Appliance assigned" in the archiver browser followed by a bunch of N/A despite the changing value of my PV. It's not seen/sampled/monitored at all  by the archiver.
the permissions
in the s/l/m write directories seem ok
ie
ls -lrt -h  /home/arch/sts/
total 4.0K
drwxr-xr-x 2 tomcat tomcat 4.0K Jul 20 16:14 ArchiverStore
looking at the logs under
ls -lrt -h   /opt/archappl/retrieval/logs/
I do not see suspicious entries, I still think something is wrong in my setup
I checked the ports, I think these are ok
sudo firewall-cmd --direct --get-rules ipv4 filter INPUT
0 -s 10.0.0.0/8 -p udp --sport 5064 -j ACCEPT
0 -s 10.0.0.0/8 -p udp --dport 5065 -j ACCEPT
0 -s 10.0.0.0/8 -p udp --sport 5075 -j ACCEPT
finally, I attach my  arch.log and my retrieval_catalina.err files
(tails pasted)
any input will be appreciated.
Thanks!
tail   /opt/archappl/retrieval/logs/arch.log
17   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading installation specific properties file from /opt/archappl/archappl.properties
19   [main] INFO  config.org.epics.archiverappliance.config.ConvertPVNameToKey  - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by :
30128 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Post startup for RETRIEVAL
30447 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn attempt limit: -1
30447 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn attempt period: 3000
30447 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn timeout: 5000
30462 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config addresses: 10.0.0.78:16670
30462 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config is redo: false
30463 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client config properties: {hazelcast.logging.type=log4j}
31945 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Start complete for webapp RETRIEVAL
[amorreal@localhost arch]$
tail   /opt/archappl/retrieval/logs/retrieval_catalina.err
Jul 24, 2020 5:11:26 PM org.epics.archiverappliance.retrieval.pva.PvaDataRetrievalServlet lambda$init$0
INFO: pool-1-thread-1
Jul 24, 2020 5:11:26 PM org.epics.archiverappliance.retrieval.pva.PvaDataRetrievalServlet init
INFO: 2020-07-24T17:11:26.878-06:00[America/Denver]pvaDataRetrievalService is operational.
Jul 24, 2020 5:11:26 PM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deployment of web application directory [/opt/archappl-2020Jul20-1614-27MDT/retrieval/webapps/retrieval] has finished in [6,405] ms
Jul 24, 2020 5:11:26 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-nio-17668"]
Jul 24, 2020 5:11:26 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in [6,501] milliseconds
Il giorno gio 23 lug 2020 alle ore 20:52 Hu, Yong <[email protected]> ha scritto:
Hi Astrid,
It seems you have a similar issue as asked on tech-talk, EPICS Archiver Appliance does not transfer PVs to "Being archived"
Good luck!
Yong
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: astrid morreale <[email protected]>
Date: Thursday, July 23, 2020 at 7:21 PM
Subject: Adding a PV to archiver appl, missing something...
Hello everyone,
I have yet another naive question as I am just starting (from zero) using EPICS and Archiver appl.
I have EPICS running and I am "ca monitoring" some PV's which are being populated---> all ok with ca monitoring I see that the PV's are changing value as I expected.
astrid@localhost epics-base]$camonitor myPV
myPV                           2020-07-23 16:44:41.905899 0
I open my archiver browser and I try to add my PV and I do not see anything happen (the PV is there but seems like a ghost).
I suspect I am missing some fundamental setting and archiver is just getting ready to connect to the PV.
"myPV
Appliance assigned
N/A
N/A
N/A
N/A
N/A
N/A
N/A"
some added info:
my env variable in bash is set to
EPICS_CA_ADDR_LIST=localhost
export EPICS_CA_ADDR_LIST
my epics base directory looks like this:
[astrid@localhost epics-base]$ ls
R3.15.5/ bin/ etc....
where my softIoc is under
epics-base/bin/linux-x86_64/softIoc
and R3.15.5 is the automatic epics installation done by archiver (following the slacmshankar/ archiver instructions online)
(I use Linux)
thanks a lot in advance.
Astrid
Astrid Morreale
Staff Scientist Subatomic Physics Group.
Los Alamos National Laboratory.
[email protected]
Astrid Morreale
[email protected]
0    [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Archiver Appliance Version 0.0.1_master_H649cc2a_B2020Jul15-2234-24MDT_T
1    [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  -
6    [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - My identity is appliance0 and my mgmt URL is http://10.0.0.78:17665/mgmt/bpl
8    [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading archappl.properties using the environment/JVM property from /opt/archappl/archappl.properties
9    [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading installation specific properties file from /opt/archappl/archappl.properties
11   [main] INFO  config.org.epics.archiverappliance.config.ConvertPVNameToKey  - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by :
30133 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Post startup for RETRIEVAL
30349 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn attempt limit: -1
30349 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn attempt period: 3000
30349 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn timeout: 5000
30362 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config addresses: 10.0.0.78:16670
30362 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config is redo: false
30362 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client config properties: {hazelcast.logging.type=log4j}
31393 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Start complete for webapp RETRIEVAL
13   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - My identity is appliance0 and my mgmt URL is http://10.0.0.78:17665/mgmt/bpl
16   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading archappl.properties using the environment/JVM property from /opt/archappl/archappl.properties
18   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading installation specific properties file from /opt/archappl/archappl.properties
20   [main] INFO  config.org.epics.archiverappliance.config.ConvertPVNameToKey  - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by :
30186 [http-nio-17668-exec-2] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Post startup for RETRIEVAL
30384 [http-nio-17668-exec-2] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn attempt limit: -1
30384 [http-nio-17668-exec-2] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn attempt period: 3000
30384 [http-nio-17668-exec-2] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn timeout: 5000
30393 [http-nio-17668-exec-2] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config addresses: 10.0.0.78:16670
30393 [http-nio-17668-exec-2] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config is redo: false
30393 [http-nio-17668-exec-2] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client config properties: {hazelcast.logging.type=log4j}
31593 [http-nio-17668-exec-2] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Start complete for webapp RETRIEVAL
2    [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  -
14   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - My identity is appliance0 and my mgmt URL is http://10.0.0.78:17665/mgmt/bpl
26   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading archappl.properties using the environment/JVM property from /opt/archappl/archappl.properties
26   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading installation specific properties file from /opt/archappl/archappl.properties
28   [main] INFO  config.org.epics.archiverappliance.config.ConvertPVNameToKey  - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by :
30371 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Post startup for RETRIEVAL
30575 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn attempt limit: -1
30575 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn attempt period: 3000
30575 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn timeout: 5000
30584 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config addresses: 10.0.0.78:16670
30584 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config is redo: false
30584 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client config properties: {hazelcast.logging.type=log4j}
31728 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Start complete for webapp RETRIEVAL
Attachment: retrieval_catalina.err
Description: Binary data
Adding a PV to archiver appl, missing something... astrid morreale via Tech-talk
Re: Adding a PV to archiver appl, missing something... Hu, Yong via Tech-talk
Prev: RE: ADProsilica crashing on RHEL7 3.10.0-1127 Mark Rivers via Tech-talk
Next: Re: ADProsilica crashing on RHEL7 3.10.0-1127 Michael Dunning via Tech-talk
Prev: Re: Adding a PV to archiver appl, missing something... Hu, Yong via Tech-talk
Next: Re: Adding a PV to archiver appl, missing something... astrid morreale via Tech-talk
