Subject: Re: Adding a PV to archiver appl, missing something...
From: astrid morreale via Tech-talk <[email protected]>
To: Abdalla Ahmad <[email protected]>
Cc: [email protected]
Date: Sun, 26 Jul 2020 16:15:24 -0600
Thanks a lot Abdalla, I added those ports you suggested and now I am seeing more output in the  logs.
1. the catalina error first warns me(then goes to error) about a memory leak...and threadlocal key?
something should have been cleaned up but I am not sure where these keys are.
2. The arch log file warne me about an access denied  "1818 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService  - Exception parsing storage metrics url pb://localhost?name=STS&rootFolder=${ARCHAPPL_SHORT_TERM_FOLDER}&partitionGranularity=PARTITION_HOUR&consolidateOnShutdown=true
java.nio.file.AccessDeniedException: /home/arch/sts"
yet this directory should be readable
ls -lrt -h  /home/arch/sts
lrwxrwxrwx 1 tomcat tomcat 43 Jul 20 16:07 /home/arch/sts -> '/run/media/amorreal/Linux ext/archiver/shm/"
Could it be because the simlink points to an external drive?
the two log files are pasted below (from the first warning/error on)
thanks again in advance
Astrid
> more mgmt_catalina.err
Jul 26, 2020 3:58:44 PM org.apache.catalina.loader.WebappClassLoaderBase clearReferencesThreads
WARNING: The web application [mgmt] appears to have started a thread named [Event bus] but has failed to stop it. This is very likely to create a memory leak. Stac
k trace of thread:
 sun.misc.Unsafe.park(Native Method)
 java.util.concurrent.locks.LockSupport.park(LockSupport.java:175)
 java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2039)
 java.util.concurrent.LinkedBlockingQueue.take(LinkedBlockingQueue.java:442)
 java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1074)
 java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1134)
 java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
 java.lang.Thread.run(Thread.java:748)
Jul 26, 2020 3:58:44 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks
SEVERE: The web application [mgmt] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@1da78c7c]) and a value of type [org
.python.core.ThreadState] (value [org.python.core.ThreadState@15402cf4]) but failed to remove it when the web application was stopped. Threads are going to be rene
wed over time to try and avoid a probable memory leak.
.python.core.ThreadState] (value [org.python.core.ThreadState@2cd2fdd8]) but failed to remove it when the web application was stopped. Threads are going to be rene
.python.core.ThreadState] (value [org.python.core.ThreadState@7018c94]) but failed to remove it when the web application was stopped. Threads are going to be renew
Jul 26, 2020 3:58:44 PM org.apache.coyote.AbstractProtocol stop
INFO: Stopping ProtocolHandler ["http-nio-17665"]
Jul 26, 2020 3:58:44 PM org.apache.coyote.AbstractProtocol destroy
INFO: Destroying ProtocolHandler ["http-nio-17665"]
Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log
INFO: Server version name:   Apache Tomcat/9.0.36
INFO: Server built:          Dec 12 1969 11:45:33 UTC
INFO: Server version number: 9.0.36.0
INFO: OS Name:               Linux
INFO: OS Version:            5.7.8-200.fc32.x86_64
INFO: Architecture:          amd64
INFO: Java Home:             /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.252.b09-1.fc32.x86_64/jre
INFO: JVM Version:           1.8.0_252-b09
INFO: JVM Vendor:            Oracle Corporation
INFO: CATALINA_BASE:         /opt/archappl-2020Jul20-1614-27MDT/mgmt
INFO: CATALINA_HOME:         /usr/share/tomcat
INFO: Command line argument: -XX:MaxMetaspaceSize=256M
INFO: Command line argument: -XX:+UseG1GC
INFO: Command line argument: -Xms512M
INFO: Command line argument: -Xmx512M
INFO: Command line argument: -ea
INFO: Command line argument: -Dcatalina.base=/opt/archappl/mgmt
INFO: Command line argument: -Dcatalina.home=/usr/share/tomcat
INFO: Command line argument: -Dcommons.daemon.process.id=73885
INFO: Command line argument: -Dcommons.daemon.process.parent=73884
INFO: Command line argument: -Dcommons.daemon.version=1.2.2
INFO: Command line argument: abort
Jul 26, 2020 3:59:00 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: Loaded Apache Tomcat Native library [1.2.23] using APR version [1.7.0].
INFO: APR capabilities: IPv6 [true], sendfile [true], accept filters [false], random [true].
INFO: APR/OpenSSL configuration: useAprConnector [false], useOpenSSL [true]
Jul 26, 2020 3:59:00 PM org.apache.catalina.core.AprLifecycleListener initializeSSL
INFO: OpenSSL successfully initialized [OpenSSL 1.1.1g FIPS  21 Apr 2020]
Jul 26, 2020 3:59:01 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-nio-17665"]
Jul 26, 2020 3:59:01 PM org.apache.catalina.startup.Catalina load
INFO: Server initialization in [1,140] milliseconds
Jul 26, 2020 3:59:01 PM org.apache.catalina.core.StandardService startInternal
--More--(99%)
>sudo more arch.log
0    [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Archiver Appliance Version 0.0.1_master_H649cc2a_B2020Jul15-2234-24MDT_T
5    [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  -
18   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - My identity is appliance0 and my mgmt URL is http://10.0.0.78:17665/mgmt/bpl
24   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading archappl.properties using the environment/JVM property from /opt/archap
pl/archappl.properties
32   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading installation specific properties file from /opt/archappl/archappl.
properties
177  [main] INFO  config.org.epics.archiverappliance.config.ConvertPVNameToKey  - The pv name components in this installation are separated by these characters [\:
\-] and the key names are terminated by :
10183 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Post startup for MGMT
10444 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Setting my cluster port base to 16670 and using interface 10.0.0.7
8
11698 [Startup executor] INFO  config.org.epics.archiverappliance.config.persistence.MySQLPersistence  - Looking up datasource called jdbc/archappl in the java:/co
mp/env namespace using JDNI
11698 [Startup executor] INFO  config.org.epics.archiverappliance.config.persistence.MySQLPersistence  - Found datasource called jdbc/archappl in the java:/comp/en
11698 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading PVTypeInfo from persistence
11818 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService  - Exception parsing storage metrics url pb://localhost?name=STS&rootFolder=
        at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84)
        at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102)
        at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107)
        at sun.nio.fs.UnixFileSystemProvider.checkAccess(UnixFileSystemProvider.java:308)
        at java.nio.file.Files.createDirectories(Files.java:746)
        at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.setRootFolder(PlainPBStoragePlugin.java:497)
        at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.initialize(PlainPBStoragePlugin.java:385)
        at org.epics.archiverappliance.config.StoragePluginURLParser.parsePlainPBStoragePlugin(StoragePluginURLParser.java:123)
        at org.epics.archiverappliance.config.StoragePluginURLParser.parseETLDest(StoragePluginURLParser.java:103)
        at org.epics.archiverappliance.config.ApplianceAggregateInfo.addInfoForPV(ApplianceAggregateInfo.java:46)
        at org.epics.archiverappliance.config.DefaultConfigService.loadTypeInfosFromPersistence(DefaultConfigService.java:1758)
        at org.epics.archiverappliance.config.DefaultConfigService.postStartup(DefaultConfigService.java:725)
        at org.epics.archiverappliance.mgmt.MgmtPostStartup.run(MgmtPostStartup.java:44)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
        at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
        at java.lang.Thread.run(Thread.java:748)
11820 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService  - Exception parsing storage metrics url pb://localhost?name=MTS&rootFolder=${ARCHAPPL_MEDIUM_TERM_FOLDER}&par
titionGranularity=PARTITION_DAY&hold=2&gather=1
java.nio.file.AccessDeniedException: /home/arch/mts
11820 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService  - Exception parsing storage metrics url pb://localhost?name=LTS&rootFolder=${ARCHAPPL_LONG_TERM_FOLDER}&parti
tionGranularity=PARTITION_YEAR
java.nio.file.AccessDeniedException: /home/arch/lts
11821 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService  - Exception parsing storage metrics url pb://localhost?name=STS&rootFolder=${ARCHAPPL_SHORT_TERM_FOLDER}&part
11821 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService  - Exception parsing storage metrics url pb://localhost?name=MTS&rootFolder=${ARCHAPPL_MEDIUM_TERM_FOLDER}&par
11822 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService  - Exception parsing storage metrics url pb://localhost?name=LTS&rootFolder=${ARCHAPPL_LONG_TERM_FOLDER}&parti
11822 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService  - Exception parsing storage metrics url pb://localhost?name=STS&rootFolder=${ARCHAPPL_SHORT_TERM_FOLDER}&part
11823 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService  - Exception parsing storage metrics url pb://localhost?name=MTS&rootFolder=${ARCHAPPL_MEDIUM_TERM_FOLDER}&par
11823 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService  - Exception parsing storage metrics url pb://localhost?name=LTS&rootFolder=${ARCHAPPL_LONG_TERM_FOLDER}&parti
11823 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading 3 PVs from persistence into cluster
11823 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading aliases from persistence
11824 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading 0 aliases from persistence into cluster
11824 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading archive requests from persistence
11825 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading 0 archive pv requests from persistence into cluster
11825 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Loading external servers from persistence
11825 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading external servers from persistence
11831 [Startup executor] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Start complete for webapp MGMT
11831 [Startup executor] INFO  config.org.epics.archiverappliance.mgmt.MgmtPostStartup  - Finished post startup for the mgmt webapp
30432 [http-nio-17665-exec-4] INFO  config.org.epics.archiverappliance.mgmt.WebappReady  - Received webAppReady from RETRIEVAL
30509 [http-nio-17665-exec-5] INFO  config.org.epics.archiverappliance.mgmt.WebappReady  - Received webAppReady from ETL
30988 [http-nio-17665-exec-6] INFO  config.org.epics.archiverappliance.mgmt.WebappReady  - Received webAppReady from ENGINE
32133 [http-nio-17665-exec-6] INFO  config.org.epics.archiverappliance.mgmt.MgmtRuntimeState  - All components in this appliance have started up. We should be ready to start accepting UI request
32134 [http-nio-17665-exec-6] INFO  config.org.epics.archiverappliance.mgmt.MgmtRuntimeState  - Starting archive requests after an initial delay (in s) of 10
86192 [http-nio-17665-exec-5] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Obtained policies location from environment /opt/archappl/ess_policies.py
---current port listing
 >sudo firewall-cmd --direct --get-rules ipv4 filter INPUT
0 -s 10.0.0.0/8 -p udp --sport 5064 -j ACCEPT
0 -s 10.0.0.0/8 -p udp --dport 5065 -j ACCEPT
0 -s 10.0.0.0/8 -p udp --sport 5075 -j ACCEPT
0 -s 10.0.0.0/8 -p udp --dport 5064 -j ACCEPT
0 -s 10.0.0.0/8 -p tcp --dport 5065 -j ACCEPT
0 -s 10.0.0.0/8 -p tcp --dport 5075 -j ACCEPT
0 -s 10.0.0.0/8 -p udp --sport 16670 -j ACCEPT
0 -s 10.0.0.0/8 -p udp --sport 17665 -j ACCEPT
0 -s 10.0.0.0/8 -p udp --sport 17666 -j ACCEPT
0 -s 10.0.0.0/8 -p udp --sport 17667 -j ACCEPT
0 -s 10.0.0.0/8 -p udp --sport 17668 -j ACCEPT
0 -s 10.0.0.0/8 -p tcp --sport 16670 -j ACCEPT
0 -s 10.0.0.0/8 -p tcp --sport 17666 -j ACCEPT
0 -s 10.0.0.0/8 -p tcp --sport 17665 -j ACCEPT
0 -s 10.0.0.0/8 -p tcp --sport 17667 -j ACCEPT
0 -s 10.0.0.0/8 -p tcp --sport 17668 -j ACCEPT
Il giorno dom 26 lug 2020 alle ore 04:52 Abdalla Ahmad <[email protected]> ha scritto:
Could it be a firewall issue? The iptables rules you are showing are for EPICS, the archiver is using few different ports. Try allowing the custom ports that the archiver is using: 16670, 17665, 17666, 17667 and 17668 in firewall-cmd or just flush the firewall rules :)
Best Regards,
Abdalla
From: Tech-talk <[email protected]> On Behalf Of astrid morreale via Tech-talk
Sent: Saturday, July 25, 2020 2:26 AM
To: Hu, Yong <[email protected]>
Thanks Yong, I took a look at the https://epics.anl.gov/tech-talk/2017/msg00705.php thread and checked the various hints, unfortunately I do think what is suggested in those threads is the problem (?).
My PV shows "Appliance assigned" in the archiver browser followed by a bunch of N/A despite the changing value of my PV. It's not seen/sampled/monitored at all  by the archiver.
the permissions
in the s/l/m write directories seem ok
ie
ls -lrt -h  /home/arch/sts/
total 4.0K
drwxr-xr-x 2 tomcat tomcat 4.0K Jul 20 16:14 ArchiverStore
looking at the logs under
ls -lrt -h   /opt/archappl/retrieval/logs/
I do not see suspicious entries, I still think something is wrong in my setup
I checked the ports, I think these are ok
finally, I attach my  arch.log and my retrieval_catalina.err files
(tails pasted)
any input will be appreciated.
Thanks!
tail   /opt/archappl/retrieval/logs/arch.log
17   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Done loading installation specific properties file from /opt/archappl/archappl.properties
19   [main] INFO  config.org.epics.archiverappliance.config.ConvertPVNameToKey  - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by :
30128 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Post startup for RETRIEVAL
30447 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn attempt limit: -1
30447 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn attempt period: 3000
30447 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config conn timeout: 5000
30462 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config addresses: 10.0.0.78:16670
30462 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client network config is redo: false
30463 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - client config properties: {hazelcast.logging.type=log4j}
31945 [http-nio-17668-exec-1] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - Start complete for webapp RETRIEVAL
[amorreal@localhost arch]$
tail   /opt/archappl/retrieval/logs/retrieval_catalina.err
Jul 24, 2020 5:11:26 PM org.epics.archiverappliance.retrieval.pva.PvaDataRetrievalServlet lambda$init$0
INFO: pool-1-thread-1
Jul 24, 2020 5:11:26 PM org.epics.archiverappliance.retrieval.pva.PvaDataRetrievalServlet init
INFO: 2020-07-24T17:11:26.878-06:00[America/Denver]pvaDataRetrievalService is operational.
Jul 24, 2020 5:11:26 PM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deployment of web application directory [/opt/archappl-2020Jul20-1614-27MDT/retrieval/webapps/retrieval] has finished in [6,405] ms
Jul 24, 2020 5:11:26 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-nio-17668"]
Jul 24, 2020 5:11:26 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in [6,501] milliseconds
Il giorno gio 23 lug 2020 alle ore 20:52 Hu, Yong <[email protected]> ha scritto:
Hi Astrid,
It seems you have a similar issue as asked on tech-talk, EPICS Archiver Appliance does not transfer PVs to "Being archived"
Good luck!
Yong
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: astrid morreale <[email protected]>
Date: Thursday, July 23, 2020 at 7:21 PM
Subject: Adding a PV to archiver appl, missing something...
Hello everyone,
I have yet another naive question as I am just starting (from zero) using EPICS and Archiver appl.
I have EPICS running and I am "ca monitoring" some PV's which are being populated---> all ok with ca monitoring I see that the PV's are changing value as I expected.
astrid@localhost epics-base]$camonitor myPV
myPV                           2020-07-23 16:44:41.905899 0
I open my archiver browser and I try to add my PV and I do not see anything happen (the PV is there but seems like a ghost).
I suspect I am missing some fundamental setting and archiver is just getting ready to connect to the PV.
"myPV
Appliance assigned
N/A
N/A
N/A
N/A
N/A
N/A
N/A"
some added info:
my env variable in bash is set to
EPICS_CA_ADDR_LIST=localhost
export EPICS_CA_ADDR_LIST
my epics base directory looks like this:
[astrid@localhost epics-base]$ ls
R3.15.5/ bin/ etc....
where my softIoc is under
epics-base/bin/linux-x86_64/softIoc
and R3.15.5 is the automatic epics installation done by archiver (following the slacmshankar/ archiver instructions online)
(I use Linux)
thanks a lot in advance.
Astrid
Astrid Morreale
Staff Scientist Subatomic Physics Group.
Los Alamos National Laboratory.
[email protected]
Astrid Morreale
[email protected]
Astrid Morreale
[email protected]
Re: Adding a PV to archiver appl, missing something... Michael Davidsaver via Tech-talk
Adding a PV to archiver appl, missing something... astrid morreale via Tech-talk
Re: Adding a PV to archiver appl, missing something... Hu, Yong via Tech-talk
Re: Adding a PV to archiver appl, missing something... astrid morreale via Tech-talk
Prev: Re: How to check IOC connection Jong Woo Kim via Tech-talk
Next: Re: Adding a PV to archiver appl, missing something... Michael Davidsaver via Tech-talk
Prev: Re: Adding a PV to archiver appl, missing something... astrid morreale via Tech-talk
