1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: MiniPIX TPX3 detector
From: "Gofron, Kazimierz via Tech-talk" <[email protected]>
To: "Wang Xiaoqiang (PSI)" <[email protected]>
Date: Mon, 3 Aug 2020 19:47:33 +0000
Hi Xiaoqiang,
Appreciated, and I will try the server when detector arrives.
Kazimierz
Sent: Monday, August 3, 2020 3:42 PM
To: Gofron, Kazimierz <[email protected]>
Cc: [email protected] <[email protected]>
I put up the code here.
https://github.com/paulscherrerinstitute/pixet_epics
Best
Xiaoqiang
> On 3 Aug 2020, at 19:33, Gofron, Kazimierz <[email protected]> wrote:
> Hi Xiaoqiang,
> Please upload the script, since this might be the quickest way to get this compact detector running.
> Kazimierz
> From: Wang Xiaoqiang (PSI) <[email protected]>
> Sent: Monday, August 3, 2020 12:06 PM
> Hi,
> This type of detector is controlled via their Pixet program,
> which has an embedded Python interpreter. Then inside the program,
> Python scripts can be loaded to call its API functions.
> We found it mostly easy to run a PCASpy server. In case you are
> interested in this approach, I can upload the script.
> Best
> Xiaoqiang
> > On 3 Aug 2020, at 17:49, Gofron, Kazimierz via Tech-talk <[email protected]> wrote:
> > Hi,
> > Has anyone created EPICS support for MiniPIX TPX3 detector (with USB2 interface) in Linux?  Thanks.
> > https://urldefense.com/v3/__https://advacam.com/minipix__;!!P4SdNyxKAPE!TmgJH5XbuSkGliqnE9pGcGUxgo6g9M73xrgPxbvc0g1DpoVtGo3eylabZIEpzsCw$
> > Regards,
> > Kazimierz
MiniPIX TPX3 detector Gofron, Kazimierz via Tech-talk
Re: MiniPIX TPX3 detector Wang Xiaoqiang (PSI) via Tech-talk
Re: MiniPIX TPX3 detector Gofron, Kazimierz via Tech-talk
Prev: Re: MiniPIX TPX3 detector Wang Xiaoqiang (PSI) via Tech-talk
Next: Temperature in camera. Jong Woo Kim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
