1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: MVME-162 CPU Boards
From: Heinz Junkes via Tech-talk <[email protected]>
To: Amit Chauhan <[email protected]>
Date: Thu, 13 Aug 2020 09:58:45 +0200
Have you checked the power supplies. Are all voltages present?
+5 V
-5 V (?)
+12 V
-12 V
Viele Grüße
Heinz
> On 13. Aug 2020, at 07:55, Amit Chauhan via Tech-talk <[email protected]> wrote:
> Hi Mark,
> The problem we are facing is that a couple of boards that were working since a long time have developed fault in-situ and stopped working.
> The indication LEDs labelled FAIL (for board fail signal) and STAT (for halt conditions) are continuously glowing. There is no communication on serial port.
> Regards,
> Amit
> On 07-08-2020 17:13, Mark Rivers wrote:
>> Hi Amit,
>> What kind of hardware issues are you having?
>> One of the problems we had several times was that when the boards were installed or removed from the VME crate the back side of the board could scrape against the VME chassis and damage some of the solder connections or wire jumpers.  Look carefully at the back side of the board for such damage.  We were able to fix them with wire jumpers.
>> I think there is also a battery that can need replacing that is used for the "non-volatile" memory where the boot parameters are stored.
>> Mark
>> ________________________________
>> From: Tech-talk
>> <[email protected]> on behalf of Amit Chauhan via Tech-talk <[email protected]>
>> Sent: Friday, August 7, 2020 2:21 AM
>> To:
>> [email protected]
>> Subject: MVME-162 CPU Boards
>> Dear All,
>> The subject matter of this mail may seem little out of context as far as EPICS is considered. But I believe this community has quite a wide experience and expertise on related matters also.
>> This is regarding VME based CPU boards from Motorola which were once very popular : MVME-162 ( 68040 processor based)
>> I would like to know if anyone has experience of hardware troubleshooting and repairing of these boards.
>> Thanks & Regards,
>> Amit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: MVME-162 CPU Boards Amit Chauhan via Tech-talk
Re: MVME-162 CPU Boards Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] Phoebus X-Y Graph Florian Feldbauer via Tech-talk
Next: Re: MVME-162 CPU Boards Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: MVME-162 CPU Boards Amit Chauhan via Tech-talk
Next: Re: MVME-162 CPU Boards Amit Chauhan via Tech-talk
