Subject: Re: MVME-162 CPU Boards
From: Amit Chauhan via Tech-talk <[email protected]>
To: Heinz Junkes <[email protected]>
Date: Thu, 13 Aug 2020 18:20:41 +0530
Dear Heinz,
Ya I have checked all the voltages and they are fine.
The boards are not working in other VME crates also.
Can some momentary power transition (over voltage, spike, ripple) affect the boards in this way ?
Amit
On 13-08-2020 13:28, Heinz Junkes wrote:
Have you checked the power supplies. Are all voltages present?
+5 V
-5 V (?)
+12 V
-12 V
Viele Grüße
Heinz
On 13. Aug 2020, at 07:55, Amit Chauhan via Tech-talk <[email protected]> wrote:
Hi Mark,
The problem we are facing is that a couple of boards that were working since a long time have developed fault in-situ and stopped working.
The indication LEDs labelled FAIL (for board fail signal) and STAT (for halt conditions) are continuously glowing. There is no communication on serial port.
Amit
On 07-08-2020 17:13, Mark Rivers wrote:
Hi Amit,
What kind of hardware issues are you having?
One of the problems we had several times was that when the boards were installed or removed from the VME crate the back side of the board could scrape against the VME chassis and damage some of the solder connections or wire jumpers.  Look carefully at the back side of the board for such damage.  We were able to fix them with wire jumpers.
I think there is also a battery that can need replacing that is used for the "non-volatile" memory where the boot parameters are stored.
<[email protected]> on behalf of Amit Chauhan via Tech-talk <[email protected]>
Sent: Friday, August 7, 2020 2:21 AM
To:
[email protected]
Subject: MVME-162 CPU Boards
Dear All,
The subject matter of this mail may seem little out of context as far as EPICS is considered. But I believe this community has quite a wide experience and expertise on related matters also.
This is regarding VME based CPU boards from Motorola which were once very popular : MVME-162 ( 68040 processor based)
I would like to know if anyone has experience of hardware troubleshooting and repairing of these boards.
Thanks & Regards,
Amit
Re: MVME-162 CPU Boards Michael Davidsaver via Tech-talk
MVME-162 CPU Boards Amit Chauhan via Tech-talk
Re: MVME-162 CPU Boards Mark Rivers via Tech-talk
Re: MVME-162 CPU Boards Amit Chauhan via Tech-talk
Re: MVME-162 CPU Boards Heinz Junkes via Tech-talk
Prev: Re: Building with debug information Ben Franksen via Tech-talk
Next: Re: Lucid Vision Cameras Mark Rivers via Tech-talk
Prev: Re: MVME-162 CPU Boards Heinz Junkes via Tech-talk
Next: Re: MVME-162 CPU Boards Michael Davidsaver via Tech-talk
