1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: websocket connection via Streamdevice
From: Freddie Akeroyd - UKRI STFC via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, "Hetz, Benjamin" <[email protected]>
Date: Wed, 19 Aug 2020 12:40:28 +0000
It looks like CAEN provide a python library for access via the websocket, so maybe using https://github.com/mdavidsaver/pyDevSup/  is another option
Freddie
From: Tech-talk <[email protected]> On Behalf Of Johnson, Andrew N. via Tech-talk
Sent: 19 August 2020 12:58
To: Hetz, Benjamin <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Subject: Re: websocket connection via Streamdevice
Hi Benjamin,
On Aug 19, 2020, at 12:59 AM, Hetz, Benjamin via Tech-talk <[email protected]> wrote:
I have a CAEN N1081A programable unit which uses websocket with a json based control protocol for communication. I guess the json part is simple to implement in streamdevice. I am not sure about the websocket part.
Is it possible to connect to a websocket device via streamdevice. Or has anybody ever used such an CAEN unit?
There are a number of C and C++ websocket libraries available, but to use one of them from StreamDevice would need integrating with Asyn and another kind of serial port creating that uses one of them. I haven’t heard of anyone doing that yet; it should be possible, but would be a fair amount of work.
- Andrew
Complexity comes for free, simplicity you have to work for.
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
AW: websocket connection via Streamdevice Hetz, Benjamin via Tech-talk
Re: websocket connection via Streamdevice Johnson, Andrew N. via Tech-talk
Prev: AW: websocket connection via Streamdevice Hetz, Benjamin via Tech-talk
Next: AW: websocket connection via Streamdevice Hetz, Benjamin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
