Subject: Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers
From: "Gofron, Kazimierz via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, "'J. Lewis Muir'" <[email protected]>
Date: Tue, 25 Aug 2020 23:00:49 +0000
Hi Mark,
The updated ADViewers/ImageJ/EPICS_areaDetector works properly with debian imagej package and default Java 11 on
  1. Ubuntu 20.04
  2. Debian 10
kaz@kaz-desktop:/epics/utils/ADViewers/ImageJ/EPICS_areaDetector$ java --version     {Ubuntu 20.04}
openjdk 11.0.8 2020-07-14
OpenJDK Runtime Environment (build 11.0.8+10-post-Ubuntu-0ubuntu120.04)
OpenJDK 64-Bit Server VM (build 11.0.8+10-post-Ubuntu-0ubuntu120.04, mixed mode, sharing)
Also the newest EPICS .jar files are available from
C:\Users\Kaz\Downloads\EPICS-Java-7.0.6.tar\EPICS-Java-7.0.6\core>ls -l
total 7356
-rw-r--r-- 1 Kaz 197121  266160 May 12 13:57 epics-ntypes-0.3.5-javadoc.jar
-rw-r--r-- 1 Kaz 197121   66215 May 12 13:57 epics-ntypes-0.3.5-sources.jar
-rw-r--r-- 1 Kaz 197121   84269 May 12 13:57 epics-ntypes-0.3.5.jar
-rw-r--r-- 1 Kaz 197121 1442422 May 12 13:58 epics-pvaccess-5.1.5-javadoc.jar
-rw-r--r-- 1 Kaz 197121  346232 May 12 13:57 epics-pvaccess-5.1.5-sources.jar
-rw-r--r-- 1 Kaz 197121  466524 May 12 13:57 epics-pvaccess-5.1.5.jar
-rw-r--r-- 1 Kaz 197121 1199525 May 12 13:57 epics-pvdata-6.1.5-javadoc.jar
-rw-r--r-- 1 Kaz 197121  217144 May 12 13:57 epics-pvdata-6.1.5-sources.jar
-rw-r--r-- 1 Kaz 197121  296459 May 12 13:57 epics-pvdata-6.1.5.jar
-rw-r--r-- 1 Kaz 197121  440648 May 12 13:57 epics-util-1.0.3-javadoc.jar
-rw-r--r-- 1 Kaz 197121   78738 May 12 13:57 epics-util-1.0.3-sources.jar
-rw-r--r-- 1 Kaz 197121  137925 May 12 13:57 epics-util-1.0.3.jar
-rw-r--r-- 1 Kaz 197121 1646633 May 12 12:23 jca-2.4.5-javadoc.jar
-rw-r--r-- 1 Kaz 197121  379405 May 12 12:22 jca-2.4.5-sources.jar
-rw-r--r-- 1 Kaz 197121  432022 May 12 12:22 jca-2.4.5.jar
I am not sure where epics-pvaclient-4.3.2.jar comes from.
Thanks for this upgrade of ImageJ ADViewer.
Kaz
Sent: Tuesday, August 25, 2020 12:40 PM
To: Gofron, Kazimierz <[email protected]>; 'J. Lewis Muir' <[email protected]>
Cc: [email protected] <[email protected]>
Subject: RE: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers
Hi Kaz,
I have updated the .jar files in ADViewers/ImageJ/EPICS_areaDetector on Github  as follows:
caj-1.1.10.jar              Deleted, not needed.
epics-ntypes-0.3.5.jar      Updated from 0.3.1
epics-pvaccess-5.1.5.jar    Updated from 5.1.1
epics-pvdata-6.1.5.jar      Updated from 6.1.1
epics-pvdatabase-4.3.1.jar  Deleted, not needed
epics-util-1.0.3.jar        New file, needed by new version of pvAccess
jca-2.4.5.jar               Updated from 2.3.6
I have tested on Centos 7 and Windows 10 using a fresh ImageJ/plugins/EPICS_areaDetector from the master branch ADViewers.  Both the EPICS_AD_Viewer (Channel Access) and the EPICS_NTNDA_Viewer (pvAccess) work fine using the latest ImageJ (1.53d) and the jre that comes with that.
Kaz, please test to see if the master branch works with your Java 11 system.  The dependency on Corba should be gone, so it should work.
Answers to your questions:
Ø  epics-pvaclient-4.3.2.jar {Source location}
Source location is https://github.com/epics-base/pvaClientJava.  However, unlike epicsCoreJava the .tar.gz files for pvaClientJava do not include .jar files.
Ø  jna-5.1.0.jar {What is this}
This is Java Native Access.  https://github.com/java-native-access/jna.  It is used to call the decompression codecs (JPEG, Blosc, bitshuffle, etc.) from ImageJ for compressed NTNDArrays.
Ø  NetCDF_.jar {Source location}
Source location is https://lmb.informatik.uni-freiburg.de/resources/opensource/imagej_plugins/netcdf.html.
Sent: Tuesday, August 25, 2020 9:55 AM
To: Mark Rivers <[email protected]>; 'J. Lewis Muir' <[email protected]>
Mark,
The .jar files in current ADViewer distribution:
  1. caj-1.1.10.jar
  2. epics-ntypes-0.3.1.jar
  3. epics-pvaccess-5.1.1.jar
  4. epics-pvaclient-4.3.2.jar
  5. epics-pvdata-6.1.1.jar
  6. epics-pvdatabase-4.3.1.jar
  7. jca-2.3.6.jar
  8. jna-5.1.0.jar
  9. NetCDF_.jar
I am not sure where sources for
·         epics-pvaclient-4.3.2.jar {Source location}
·         jna-5.1.0.jar {What is this}
·         NetCDF_.jar {Source location}
Is epics-pvdatabase-4.3.1.jar needed?
Remaining most recent .jar files are distributed. The jca and caj is combined into jca, I think.
Kaz
Sent: Tuesday, August 25, 2020 9:42 AM
To: 'J. Lewis Muir' <[email protected]>; Gofron, Kazimierz <[email protected]>
It appears that the CORBA dependency in pvAccess was removed in this commit in June 2018.
https://github.com/epics-base/epicsCoreJava/commit/1d300d365c91b7fdc89bb93ee4d7b4b3241c734a#diff-91dff54d9f3689d9045dbd98eea6b1f2
I will work on updating ADViewers to use the most recent pvAccess jar files.
-----Original Message-----
Sent: Wednesday, August 19, 2020 5:45 PM
Cc: Mark Rivers <[email protected]>; [email protected]
On 08/19, Gofron, Kazimierz via Tech-talk wrote:
> The problem is in the epics-pvaccess-5.1.1.jar. Were these jar files created with Java 8?
> strings epics-pvaccess-5.1.1.jar | grep BlockingTCPConnector
> org/epics/pvaccess/client/impl/remote/tcp/BlockingTCPConnector$Transpo
> rtFactory.class
> org/epics/pvaccess/client/impl/remote/tcp/BlockingTCPConnector.class
> rtFactory.classPK
> org/epics/pvaccess/client/impl/remote/tcp/BlockingTCPConnector.classPK
Where's the source code for the epics-pvaccess-5.1.1.jar?  Is it the following?
  https://github.com/epics-rip/pvAccessJava/tree/5.1.1
If so, that code contains three classes that reference classes in the org.omg.CORBA package that have been removed in Java 11:
  src/org/epics/pvaccess/impl/remote/IntrospectionRegistry.java
  src/org/epics/pvaccess/util/IntHashMap.java
  src/org/epics/pvaccess/util/ShortHashMap.java
I don't know anything about pvAccessJava, but if the latest version is at
then a search for "corba" there shows that it does not contain references to classes in the org.omg.CORBA package, so if you can upgrade to a newer version of pvAccessJava that does not reference CORBA classes, then I think the problem would go away.
Another solution would be to add JARs to the Java classpath providing the CORBA classes such as from JacORB:
  https://github.com/JacORB/JacORB
Yet another solution would of course be to use a Java 8 VM instead of a Java 11 VM.
Lewis
Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Mark Rivers via Tech-talk
Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Gofron, Kazimierz via Tech-talk
Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers J. Lewis Muir via Tech-talk
RE: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Mark Rivers via Tech-talk
Prev: asyn R4-40-1 available Mark Rivers via Tech-talk
Next: Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Mark Rivers via Tech-talk
Prev: RE: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Mark Rivers via Tech-talk
