1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: asyn R4-40-1 available
Date: Tue, 25 Aug 2020 20:33:20 +0000
Folks,
asyn R4-40-1 is now available.
asyn is available on github here:
https://github.com/epics-modules/asyn
tar and zip files are available here:
https://github.com/epics-modules/asyn/releases
The documentation and release notes are here:
https://epics-modules.github.io/master/asyn/
This from the R4-40-1 release notes:
- drvAsynIPPort
  - Fixed the logic for using SO_REUSEPORT or SO_RESUSEADDR. In R4-40 RTEMS and Windows used SO_REUSEADDR and all others used SO_REUSEPORT.
    This does not work because Linux kernels before 3.9 also do not support SO_REUSEPORT. Now if SO_REUSEPORT is not defined then SO_REUSEADDR is used instead.
Prev: RE: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Mark Rivers via Tech-talk
Next: Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Gofron, Kazimierz via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: EPICS 7.0.4.1 released Michael Davidsaver via Tech-talk
Next: XSPRESS3 / InternalTrigger / AcquireTime John Dobbins via Tech-talk
