Subject: Re: Alarm and logging systems
From: "Konrad, Martin via Tech-talk" <[email protected]>
To: "Garrahan, Jacqueline" <[email protected]>
Date: Wed, 2 Sep 2020 13:57:41 +0000
Hi Jackie,
At FRIB we are currently moving from BEAST to the Phoebus Alarm Server.
In my experience the Phoebus alarm system is much more reliable than
BEAST and shows better behavior when used with larger numbers of alarms.
For logging we're using the ELK stack. So far our IOCs pass log messages
directly to a central log server (actually a cluster to improve
availability) through plain TCP connections. This is not ideal. If we
find the time we want to switch towards an approach that hands over log
messages to a proper logging service/library which takes care of
delivering them to the central log server (I remember Michael also had a
few lines of code to do so). This would be more reliable in case network
connections are interrupted temporarily. This would potentially also
come with the opportunity to store logs locally when the log server is
not available and transfer them once the log server is reachable again.
-Martin
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Alarm and logging systems Garrahan, Jacqueline via Tech-talk
Prev: How to handle adjusting values as they change independent of the driver in an asynPortDriver? Wlodek, Jakub via Tech-talk
Next: Re: How to handle adjusting values as they change independent of the driver in an asynPortDriver? Mark Rivers via Tech-talk
Prev: Re: Alarm and logging systems Jeong Han Lee via Tech-talk
Next: CAEN R1470ET HVPS - Asyn + Stream Device auto connect does not recover communication Paduan Donadio, Marcio via Tech-talk
