Subject: Re: RTEMS/MVME2100 OMS58 card does not exist! error
From: Ben Franksen via Tech-talk <[email protected]>
Cc: "[email protected] ([email protected])" <[email protected]>
Date: Fri, 11 Sep 2020 21:59:40 +0200
Am 11.09.20 um 18:28 schrieb Mark Rivers via Tech-talk:
> There is a recent pull request to remove that vxWorks dependency.
> Which version of the code you are running?
I made that pull request because I had the same problem, trying to use
motorOms with RTEMS for several oms boards. While I was at it, I also
fixed all the warnings. You could help by pulling (or cloning) from
https://github.com/bfrk/motorOms and see if that works for you, and
comment on the PR with the results.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
Re: RTEMS/MVME2100 OMS58 card does not exist! error Ben Franksen via Tech-talk
RTEMS/MVME2100 OMS58 card does not exist! error Sintschuk, Michael via Tech-talk
Re: RTEMS/MVME2100 OMS58 card does not exist! error Ralph Lange via Tech-talk
RE: RTEMS/MVME2100 OMS58 card does not exist! error Mark Rivers via Tech-talk
Prev: AW: RE: Has anyone written an IOC for control of (PI)Acton spectrometers? Joern Dreyer via Tech-talk
Next: Re: RTEMS/MVME2100 OMS58 card does not exist! error Ben Franksen via Tech-talk
Prev: RE: RTEMS/MVME2100 OMS58 card does not exist! error Mark Rivers via Tech-talk
