Subject: Re: RTEMS/MVME2100 OMS58 card does not exist! error
From: Ben Franksen via Tech-talk <[email protected]>
To: "[email protected] ([email protected])" <[email protected]>
Date: Fri, 11 Sep 2020 22:02:05 +0200
Am 11.09.20 um 21:59 schrieb Ben Franksen via Tech-talk:
> Am 11.09.20 um 18:28 schrieb Mark Rivers via Tech-talk:
>> There is a recent pull request to remove that vxWorks dependency.
>> Which version of the code you are running?
> I made that pull request because I had the same problem, trying to use
> motorOms with RTEMS for several oms boards. While I was at it, I also
> fixed all the warnings. You could help by pulling (or cloning) from
> https://github.com/bfrk/motorOms and see if that works for you, and
> comment on the PR with the results.
Link to the PR is https://github.com/epics-motor/motorOms/pull/6
Attachment: signature.asc
Description: OpenPGP digital signature
RTEMS/MVME2100 OMS58 card does not exist! error Sintschuk, Michael via Tech-talk
Re: RTEMS/MVME2100 OMS58 card does not exist! error Ralph Lange via Tech-talk
RE: RTEMS/MVME2100 OMS58 card does not exist! error Mark Rivers via Tech-talk
Re: RTEMS/MVME2100 OMS58 card does not exist! error Ben Franksen via Tech-talk
Prev: Re: RTEMS/MVME2100 OMS58 card does not exist! error Ben Franksen via Tech-talk
Next: Save the date: EPICS Collaboration Meeting 2020, 19-23 October 2020 Heinz Junkes via Tech-talk
