Hi Andrew, Build finished without any obvious error messages but there were some error messages in the built-in unit tests by typing 'make -s runtests'. The attached is log file captured in the process. - Dong Ho, SHIN -----Original Message----- From: "Johnson, Andrew N." <[email protected]> To: "신동호" <[email protected]>; Cc: "EPICS tech-talk" <[email protected]>; Sent: 2020-09-16 (수) 15:15:07 (UTC+09:00) Subject: Re: Problem with installing epics base on Jetson nano Hi Dong Ho, On Sep 15, 2020, at 7:13 PM, 신동호 <[email protected]> wrote:
Thank-you, that information was very helpful. I have committed what I think should be the necessary changes to support your linux-aarch64 target to the default branch of our Git repository. Since you followed our how-to installation instructions you should be able to pull those modifications into your copy and build it as follows:
If the build stops and displays one or more error messages, please copy the errors and the build command immediately before them into an email and send it to the EPICS tech-talk list so we can try to help fix it. If the build finishes without any obvious error messages, please try running our built-in unit tests like this:
This will run several blocks of tests to check different parts of the software, displaying the results after each block. Please email us the results if you get any failures, and let us know if they all pass. Good luck, and thank-you! - Andrew -- Complexity comes for free, simplicity you have to work for.
/home/epics/EPICS/epics-base/test/tools/O.linux-aarch64
Snippets.t .. ok
All tests successful.
Files=1, Tests=29, 2 wallclock secs ( 0.06 usr 0.01 sys + 1.33 cusr 0.18 csys = 1.58 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/libcom/test/O.linux-aarch64
epicsUnitTestTest.t ........... ok
epicsTypesTest.t .............. ok
epicsInlineTest.t ............. ok
epicsCalcTest.t ............... ok
epicsAlgorithmTest.t .......... ok
epicsMathTest.t ............... ok
epicsMMIOTest.t ............... ok
epicsEllTest.t ................ ok
epicsEnvTest.t ................ ok
epicsEnvUnsetTest.t ........... ok
epicsErrlogTest.t ............. ok
epicsStdioTest.t .............. ok
epicsStdlibTest.t ............. ok
epicsSockResolveTest.t ........ ok
epicsStringTest.t ............. ok
epicsTimeTest.t ............... ok
epicsTimeZoneTest.t ........... ok
epicsThreadTest.t ............. ok
epicsThreadClassTest.t ........ ok
epicsThreadOnceTest.t ......... ok
epicsThreadPriorityTest.t ..... ok
epicsThreadPrivateTest.t ...... ok
epicsThreadHooksTest.t ........ ok
epicsThreadPoolTest.t ......... ok
epicsExitTest.t ............... ok
epicsTimerTest.t .............. ok
ringPointerTest.t ............. ok
ringBytesTest.t ............... ok
epicsEventTest.t .............. ok
epicsMutexTest.t .............. ok
epicsSpinTest.t ............... ok
epicsAtomicTest.t ............. ok
macDefExpandTest.t ............ ok
cvtFastTest.t ................. ok
macLibTest.t .................. ok
aslibtest.t ................... ok
macLib.t ...................... ok
taskwdTest.t .................. ok
blockingSockTest.t ............ ok
epicsMessageQueueTest.t ....... ok
epicsStackTraceTest.t .........
not ok 3 - dumping global symbols
not ok 4 - dumping local symbols
not ok 5 - dumping addresses
Failed 3/5 subtests
ipAddrToAsciiTest.t ........... ok
osiSockTest.t ................. ok
testexecname.t ................ ok
yajlTest.t .................... ok
iocshTest.t ................... ok
epicsLoadTest.t ............... ok
nonEpicsThreadPriorityTest.t .. ok
Test Summary Report
epicsStackTraceTest.t (Wstat: 0 Tests: 5 Failed: 3)
Failed tests: 3-5
Files=48, Tests=4274, 200 wallclock secs ( 1.61 usr 0.17 sys + 3.66 cusr 2.52 csys = 7.96 CPU)
Result: FAIL
/home/epics/EPICS/epics-base/modules/pvData/testApp/O.linux-aarch64
testThread.t ............ ok
testEvent.t ............. ok
testTimer.t ............. ok
testBitSet.t ............ ok
testOverrunBitSet.t ..... ok
testByteBuffer.t ........ ok
testBaseException.t ..... ok
testSharedVector.t ...... ok
testDebugPtr.t .......... ok
testSerialization.t ..... ok
testTimeStamp.t ......... ok
testTypeCast.t .......... ok
testUnitTest.t .......... ok
testjson.t .............. ok
test_reftrack.t ......... ok
testanyscalar.t ......... ok
testprinter.t ........... ok
testBitSetUtil.t ........ ok
testIntrospect.t ........ ok
testPVType.t ............ ok
testStandardField.t ..... ok
testStandardPVField.t ... ok
testPVData.t ............ ok
testPVUnion.t ........... ok
testConvert.t ........... ok
testPVScalarArray.t ..... ok
testPVStructureArray.t .. ok
testOperators.t ......... ok
testFieldBuilder.t ...... ok
testValueBuilder.t ...... ok
testProperty.t .......... ok
testCreateRequest.t ..... ok
Files=32, Tests=2653, 68 wallclock secs ( 0.89 usr 0.12 sys + 0.80 cusr 0.22 csys = 2.03 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/database/test/ioc/db/O.linux-aarch64
dbScanTest.t ............... ok
dbShutdownTest.t ........... ok
dbPutLinkTest.t ............ ok
dbLockTest.t ............... ok
dbStressTest.t ............. ok
testdbConvert.t ............ ok
callbackTest.t ............. ok
callbackParallelTest.t ..... ok
dbStateTest.t .............. ok
dbServerTest.t ............. ok
dbCaStatsTest.t ............ ok
dbCaLinkTest.t ............. ok
scanIoTest.t ............... ok
dbChannelTest.t ............ ok
dbChArrTest.t .............. ok
chfPluginTest.t ............ ok
arrShorthandTest.t ......... ok
recGblCheckDeadbandTest.t .. ok
testPutGetTest.t ........... ok
dbStaticTest.t ............. ok
Files=20, Tests=2873, 80 wallclock secs ( 1.06 usr 0.09 sys + 23.20 cusr 16.84 csys = 41.19 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/database/test/ioc/dbtemplate/O.linux-aarch64
msi.t .. ok
Files=1, Tests=12, 0 wallclock secs ( 0.06 usr 0.00 sys + 0.06 cusr 0.02 csys = 0.14 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/database/test/std/rec/O.linux-aarch64
arrayOpTest.t ........... ok
recMiscTest.t ........... ok
linkRetargetLinkTest.t .. ok
linkInitTest.t .......... ok
compressTest.t .......... ok
asyncSoftTest.t ......... ok
softTest.t .............. ok
seqTest.t ............... ok
asTest.t ................ ok
analogMonitorTest.t ..... ok
scanEventTest.t ......... ok
regressTest.t ........... ok
simmTest.t .............. ok
mbbioDirectTest.t ....... ok
asyncproctest.t ......... ok
netget.t ................ ok
Files=16, Tests=4392, 20 wallclock secs ( 1.09 usr 0.09 sys + 1.84 cusr 0.46 csys = 3.48 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/database/test/std/link/O.linux-aarch64
lnkStateTest.t .. ok
lnkCalcTest.t ... ok
Files=2, Tests=58, 1 wallclock secs ( 0.09 usr 0.00 sys + 0.06 cusr 0.03 csys = 0.18 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/database/test/std/filters/O.linux-aarch64
tsTest.t .... ok
dbndTest.t .. ok
arrTest.t ... ok
syncTest.t .. ok
decTest.t ... ok
Files=5, Tests=1809, 3 wallclock secs ( 0.39 usr 0.02 sys + 0.18 cusr 0.07 csys = 0.66 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/database/test/tools/O.linux-aarch64
Base.t ........ ok
Breaktable.t .. ok
DBD.t ......... ok
Device.t ...... ok
Driver.t ...... ok
Function.t .... ok
Menu.t ........ ok
Recfield.t .... ok
Recordtype.t .. ok
Registrar.t ... ok
Variable.t .... ok
Files=11, Tests=293, 2 wallclock secs ( 0.17 usr 0.01 sys + 1.39 cusr 0.18 csys = 1.75 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/pvAccess/testApp/O.linux-aarch64
testAtomicBoolean.t ..... ok
testHexDump.t ........... ok
testInetAddressUtils.t .. ok
configurationTest.t ..... ok
testFairQueue.t ......... ok
testWildcard.t .......... ok
testChannelAccess.t ..... ok
testCodec.t ............. ok
testRPC.t ............... ok
testServerContext.t ..... ok
testmonitorfifo.t ....... ok
testsharedstate.t ....... ok
Files=12, Tests=6381, 29 wallclock secs ( 1.15 usr 0.05 sys + 2.51 cusr 0.60 csys = 4.31 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/pvAccess/testCa/O.linux-aarch64
testCaProvider.t .. ok
Files=1, Tests=143, 1 wallclock secs ( 0.08 usr 0.00 sys + 0.08 cusr 0.03 csys = 0.19 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/normativeTypes/test/O.linux-aarch64
ntfieldTest.t ............... ok
ntscalarTest.t .............. ok
ntscalarArrayTest.t ......... ok
ntnameValueTest.t ........... ok
ntmultiChannelTest.t ........ ok
ntscalarMultiChannelTest.t .. ok
nttableTest.t ............... ok
ntndarrayTest.t ............. ok
ntmatrixTest.t .............. ok
ntenumTest.t ................ ok
ntunionTest.t ............... ok
ntaggregateTest.t ........... ok
ntattributeTest.t ........... ok
ntndarrayAttributeTest.t .... ok
ntcontinuumTest.t ........... ok
nthistogramTest.t ........... ok
ntutilsTest.t ............... ok
validatorTest.t ............. ok
Files=18, Tests=687, 1 wallclock secs ( 0.28 usr 0.04 sys + 0.44 cusr 0.12 csys = 0.88 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/pvDatabase/test/O.linux-aarch64
testPlugin.t ......... ok
testPVCopy.t ......... ok
testPVRecord.t ....... ok
testExampleRecord.t .. ok
testLocalProvider.t .. ok
testPVAServer.t ...... ok
Files=6, Tests=107, 0 wallclock secs ( 0.11 usr 0.01 sys + 0.16 cusr 0.04 csys = 0.32 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/pva2pva/p2pApp/O.linux-aarch64
testmon.t .. ok
Files=1, Tests=79, 0 wallclock secs ( 0.08 usr 0.00 sys + 0.02 cusr 0.00 csys = 0.10 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/pva2pva/testApp/O.linux-aarch64
testweak.t ......... ok
testtest.t ......... ok
testpvif.t ......... ok
testpdb.t .......... ok
testpvalink.t ...... ok
testgroupconfig.t .. ok
testdbf_copy.t ..... ok
Test Summary Report
testpvif.t (Wstat: 0 Tests: 88 Failed: 0)
TODO passed: 35
Files=7, Tests=342, 3 wallclock secs ( 0.20 usr 0.02 sys + 0.39 cusr 0.10 csys = 0.71 CPU)
Result: PASS
Test failures were reported in:
configure/RULES_TOP:54: recipe for target 'runtests' failed
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
