1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Issues connecting to siemens PLC
To: Anders Lindh Olsson <[email protected]>
Date: Thu, 17 Sep 2020 11:33:58 +0000
> #                                           portName,                           tcpPortName,            slaveAddr,     modbusFct,       addr,   length, dataType,       pollMsec,       plcType,
> drvModbusAsynConfigure("ESS_NBLM_PLC502_AS_WRITE_0",            "ESS_NBLM_PLC502",              1,                     16,                      0,              40,             8,                      1,                      "SIEMENS")
> 2020/09/17 09:38:36.122 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC502_AS_WRITE_0 error calling writeRead, error=172.30.150.83:502 write error: Broken pipe, nwrite=0/6, nread=0
Prior to that drvModbusAsynConfigure command you should have called drvAsynIPPortConfigure() and modbusInterposeConfig().  Did both of those calls succeed?  Prior to calling drvModbusAsynConfigure I would suggest adding this command to your startup to make sure the IP port is created and connected.
asynReport(10, "ESS_NBLM_PLC502")
From: Tech-talk <[email protected]> on behalf of Anders Lindh Olsson via Tech-talk <[email protected]>
Sent: Thursday, September 17, 2020 2:57 AM
To: [email protected]
Subject: Issues connecting to siemens PLC
I have an IOC that is supposed to control a Siemens S7 PLC using s7plc (1.4.1) and modbus (3.0.0), developed by someone that is not me. I have been running into two (possibly separate but I don’t think so) issues.
First some errors during set up:
drvModbusAsynConfigure("ESS_NBLM_PLC508_AS_WRITE_0",            "ESS_NBLM_PLC508",              1,                     16,                      0,              6,              4,                      1,                      "SIEMENS")
2020/09/17 09:38:36.122 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC508_AS_WRITE_0 error calling writeRead, error=172.30.150.83:508 write error: Broken pipe, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC509_AS_WRITE_0",            "ESS_NBLM_PLC509",              1,                     16,                      0,              2,              8,                      1,                      "SIEMENS")
2020/09/17 09:38:36.123 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC509_AS_WRITE_0 error calling writeRead, error=172.30.150.83:509 read error: Connection reset by peer, nwrite=6/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC503_AS_WRITE_0",            "ESS_NBLM_PLC503",              1,                     16,                      0,              40,             8,                      1,                      "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC503_AS_WRITE_0 error calling writeRead, error=172.30.150.83:503 write error: Broken pipe, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC504_AS_WRITE_0",            "ESS_NBLM_PLC504",              1,                     16,                      0,              40,             8,                      1,                      "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC504_AS_WRITE_0 error calling writeRead, error=172.30.150.83:504 write error: Broken pipe, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC507_AS_WRITE_0",            "ESS_NBLM_PLC507",              1,                     16,                      0,              40,             8,                      1,                      "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC507_AS_WRITE_0 error calling writeRead, error=172.30.150.83:507 write error: Broken pipe, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC505_AS_WRITE_0",            "ESS_NBLM_PLC505",              1,                     16,                      0,              40,             8,                      1,                      "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC505_AS_WRITE_0 error calling writeRead, error=172.30.150.83:505 write error: Broken pipe, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC506_AS_WRITE_0",            "ESS_NBLM_PLC506",              1,                     16,                      0,              40,             8,                      1,                      "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC506_AS_WRITE_0 error calling writeRead, error=172.30.150.83:506 write error: Broken pipe, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC502_TS_WRITE_4000",         "ESS_NBLM_PLC502",              1,                     5,                       4000,   1640,   0,                      1,                      "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC502_TS_WRITE_4000 error calling writeRead, error=asynManager::queueLockPort queueRequest failed: port ESS_NBLM_PLC502 not connected, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC502_TS_WRITE_6400",         "ESS_NBLM_PLC502",              1,                     5,                       6400,   1640,   0,                      1,                      "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC502_TS_WRITE_6400 error calling writeRead, error=asynManager::queueLockPort queueRequest failed: port ESS_NBLM_PLC502 not connected, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC502_TS_WRITE_8800",         "ESS_NBLM_PLC502",              1,                     5,                       8800,   3,              0,                      1,                      "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC502_TS_WRITE_8800 error calling writeRead, error=asynManager::queueLockPort queueRequest failed: port ESS_NBLM_PLC502 not connected, nwrite=0/6, nread=0
And later when the IOC shell is started:
04d5808-xblm-ct-25485 > 09/17/20 09:38:37.387 s7plcConnect ESS_NBLM_PLC: connected to 172.30.150.83:2000
09/17/20 09:38:37.387 s7plcReceiveThread ESS_NBLM_PLC: recv(32, ..., 534, 0) failed: Connection reset by peer
09/17/20 09:38:37.387 s7plcCloseConnection ESS_NBLM_PLC
09/17/20 09:38:38.638 s7plcConnect ESS_NBLM_PLC: connected to 172.30.150.83:2000
09/17/20 09:38:38.639 s7plcReceiveThread ESS_NBLM_PLC: recv(32, ..., 534, 0) failed: Connection reset by peer
09/17/20 09:38:38.639 s7plcCloseConnection ESS_NBLM_PLC
09/17/20 09:38:39.889 s7plcConnect ESS_NBLM_PLC: connected to 172.30.150.83:2000
09/17/20 09:38:39.890 s7plcReceiveThread ESS_NBLM_PLC: recv(32, ..., 534, 0) failed: Connection reset by peer
09/17/20 09:38:39.890 s7plcCloseConnection ESS_NBLM_PLC
Any help would be appreciated.
Cheers
Anders
RE: Issues connecting to siemens PLC Anders Lindh Olsson via Tech-talk
Prev: Re: ASLO doesn't work Vishnu Patel via Tech-talk
Next: Re: ASLO doesn't work Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Issues connecting to siemens PLC Anders Lindh Olsson via Tech-talk
Next: RE: Issues connecting to siemens PLC Anders Lindh Olsson via Tech-talk
