Hi Mark,
I had first thought that both of those calls were successful. The reports show that I am not connected on any of the modbus ports (502 through 509) with noAutoConnect (1):
ESS_NBLM_PLC502 multiDevice:No canBlock:Yes autoConnect:No
enabled:Yes connected:No numberConnects 0
nDevices 0 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 0 exceptionNotifys 0
traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
interposeInterfaceList
asynOctet pinterface 0x7fdb82c0e360 drvPvt 0xe45fd0
interfaceList
asynCommon pinterface 0x7fdb8875cf70 drvPvt 0xe3de60
asynOption pinterface 0x7fdb8875cf90 drvPvt 0xe3de60
asynOctet pinterface 0xe3df80 drvPvt 0xe3de60
Port 172.30.150.83:502: Disconnected
fd: -1
Characters written: 0
Characters read: 0
With autoconnect, I establish a connection, but the IOC appears to crash upon the first call of drvModbusAsynConfigure:
ESS_NBLM_PLC502 multiDevice:No canBlock:Yes autoConnect:Yes
enabled:Yes connected:Yes numberConnects 1
asynOctet pinterface 0x7efe82bc5360 drvPvt 0x128c050
interfaceList
asynCommon pinterface 0x7efe886dff70 drvPvt 0x1283fa0
asynOption pinterface 0x7efe886dff90 drvPvt 0x1283fa0
asynOctet pinterface 0x12840c0 drvPvt 0x1283fa0
Port 172.30.150.83:502: Connected
fd: 6
Characters read: 0
drvModbusAsynConfigure("ESS_NBLM_PLC502_AS_WRITE_0", "ESS_NBLM_PLC502", 1, 16, 0, 40, 8, 1, "SIEMENS")
[iocuser@xblm-ctrl-pc cmds]$ # i.e. just a PS1 - process dead
Anders
-----Original Message-----
Sent: Thursday, 17 September, 2020 13:34
To: Anders Lindh Olsson <[email protected]>
Cc: [email protected]
Subject: Re: Issues connecting to siemens PLC
> # portName, tcpPortName, slaveAddr, modbusFct, addr, length, dataType, pollMsec, plcType,
> 2020/09/17 09:38:36.122 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC502_AS_WRITE_0 error calling writeRead, error=172.30.150.83:502 write error: Broken pipe, nwrite=0/6, nread=0
Prior to that drvModbusAsynConfigure command you should have called drvAsynIPPortConfigure() and modbusInterposeConfig(). Did both of those calls succeed? Prior to calling drvModbusAsynConfigure I would suggest adding this command to your startup to make sure the IP port is created and connected.
asynReport(10, "ESS_NBLM_PLC502")
From: Tech-talk <[email protected]> on behalf of Anders Lindh Olsson via Tech-talk <[email protected]>
Sent: Thursday, September 17, 2020 2:57 AM
To: [email protected]
Subject: Issues connecting to siemens PLC
I have an IOC that is supposed to control a Siemens S7 PLC using s7plc (1.4.1) and modbus (3.0.0), developed by someone that is not me. I have been running into two (possibly separate but I don't think so) issues.
First some errors during set up:
drvModbusAsynConfigure("ESS_NBLM_PLC508_AS_WRITE_0", "ESS_NBLM_PLC508", 1, 16, 0, 6, 4, 1, "SIEMENS")
2020/09/17 09:38:36.122 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC508_AS_WRITE_0 error calling writeRead, error=172.30.150.83:508 write error: Broken pipe, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC509_AS_WRITE_0", "ESS_NBLM_PLC509", 1, 16, 0, 2, 8, 1, "SIEMENS")
2020/09/17 09:38:36.123 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC509_AS_WRITE_0 error calling writeRead, error=172.30.150.83:509 read error: Connection reset by peer, nwrite=6/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC503_AS_WRITE_0", "ESS_NBLM_PLC503", 1, 16, 0, 40, 8, 1, "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC503_AS_WRITE_0 error calling writeRead, error=172.30.150.83:503 write error: Broken pipe, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC504_AS_WRITE_0", "ESS_NBLM_PLC504", 1, 16, 0, 40, 8, 1, "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC504_AS_WRITE_0 error calling writeRead, error=172.30.150.83:504 write error: Broken pipe, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC507_AS_WRITE_0", "ESS_NBLM_PLC507", 1, 16, 0, 40, 8, 1, "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC507_AS_WRITE_0 error calling writeRead, error=172.30.150.83:507 write error: Broken pipe, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC505_AS_WRITE_0", "ESS_NBLM_PLC505", 1, 16, 0, 40, 8, 1, "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC505_AS_WRITE_0 error calling writeRead, error=172.30.150.83:505 write error: Broken pipe, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC506_AS_WRITE_0", "ESS_NBLM_PLC506", 1, 16, 0, 40, 8, 1, "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC506_AS_WRITE_0 error calling writeRead, error=172.30.150.83:506 write error: Broken pipe, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC502_TS_WRITE_4000", "ESS_NBLM_PLC502", 1, 5, 4000, 1640, 0, 1, "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC502_TS_WRITE_4000 error calling writeRead, error=asynManager::queueLockPort queueRequest failed: port ESS_NBLM_PLC502 not connected, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC502_TS_WRITE_6400", "ESS_NBLM_PLC502", 1, 5, 6400, 1640, 0, 1, "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC502_TS_WRITE_6400 error calling writeRead, error=asynManager::queueLockPort queueRequest failed: port ESS_NBLM_PLC502 not connected, nwrite=0/6, nread=0
drvModbusAsynConfigure("ESS_NBLM_PLC502_TS_WRITE_8800", "ESS_NBLM_PLC502", 1, 5, 8800, 3, 0, 1, "SIEMENS")
2020/09/17 09:38:36.124 drvModbusAsyn::doModbusIO port ESS_NBLM_PLC502_TS_WRITE_8800 error calling writeRead, error=asynManager::queueLockPort queueRequest failed: port ESS_NBLM_PLC502 not connected, nwrite=0/6, nread=0
And later when the IOC shell is started:
04d5808-xblm-ct-25485 > 09/17/20 09:38:37.387 s7plcConnect ESS_NBLM_PLC: connected to 172.30.150.83:2000
09/17/20 09:38:37.387 s7plcReceiveThread ESS_NBLM_PLC: recv(32, ..., 534, 0) failed: Connection reset by peer
09/17/20 09:38:37.387 s7plcCloseConnection ESS_NBLM_PLC
09/17/20 09:38:38.638 s7plcConnect ESS_NBLM_PLC: connected to 172.30.150.83:2000
09/17/20 09:38:38.639 s7plcReceiveThread ESS_NBLM_PLC: recv(32, ..., 534, 0) failed: Connection reset by peer
09/17/20 09:38:38.639 s7plcCloseConnection ESS_NBLM_PLC
09/17/20 09:38:39.889 s7plcConnect ESS_NBLM_PLC: connected to 172.30.150.83:2000
09/17/20 09:38:39.890 s7plcReceiveThread ESS_NBLM_PLC: recv(32, ..., 534, 0) failed: Connection reset by peer
09/17/20 09:38:39.890 s7plcCloseConnection ESS_NBLM_PLC
Any help would be appreciated.
Cheers
Anders
- Re: Issues connecting to siemens PLC Mark Rivers via Tech-talk
- Issues connecting to siemens PLC Anders Lindh Olsson via Tech-talk
Re: ASLO doesn't work Hu, Yong via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
