1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: ASLO doesn't work
To: Vishnu Patel <[email protected]>, EPICS Tech Talk <[email protected]>, Ralph Lange <[email protected]>
Date: Thu, 17 Sep 2020 12:00:45 +0000
Hi Vishnu,
I think you misunderstood the conversion in ai record (or I misunderstand it). EGUF & EGUL are Full & Low values in engineering unit. I do not think a vacuum value can go negative “-32768”. “-32768” seems to be a ADC raw value.
As Ralph said, the conversion probably has already been done in the driver. If your goal is just the conversion from mBar to Bar, then use a “calc” or “calcout” to do the conversion.
See the links below:
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Analog_Input
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Concepts#Conversion_Specification
Good luck!
Yong
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: Vishnu Patel <[email protected]>
Date: Thursday, September 17, 2020 at 7:14 AM
To: "[email protected]" <[email protected]>, Ralph Lange <[email protected]>
   I tried with EGUF = 32.767 , EGUL = -32.768 but the VAL was not factor of 1000. I tried with ESLO also but not result.
I am missing something.
Thanks
Vishnu
Sent from Outlook
From: Tech-talk <[email protected]> on behalf of Ralph Lange via Tech-talk <[email protected]>
Sent: 17 September 2020 16:35
To: EPICS Tech Talk <[email protected]>
On Thu, 17 Sep 2020 at 11:10, Vishnu Patel via Tech-talk <[email protected]> wrote:
record(ai, "AI0") {
    field(LINR,"LINEAR")
    field(EGUF,"32767")
    field(EGUL,"-32768")
The PLC the value is 1003.124 in mBar, i have to display as 1.0031 Bar.
As you are using linear conversion already,
wouldn't setting EGUF to 32.767 and EGUL to -32.768 result in a VAL that is smaller by a factor of 1000?
Cheers,
~Ralph
ASLO doesn't work Vishnu Patel via Tech-talk
Re: ASLO doesn't work Ralph Lange via Tech-talk
Re: ASLO doesn't work Vishnu Patel via Tech-talk
Prev: Re: ASLO doesn't work Mark Rivers via Tech-talk
Next: RE: Issues connecting to siemens PLC Anders Lindh Olsson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: ASLO doesn't work Vishnu Patel via Tech-talk
Next: Re: ASLO doesn't work Mark Rivers via Tech-talk
