1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: ASLO doesn't work
From: "Mercado, Ronaldo \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
To: 'Ben Franksen' <[email protected]>, "'[email protected]'" <[email protected]>
Date: Thu, 17 Sep 2020 16:23:12 +0000
I can confirm that Ben has correctly diagnosed that device support returns "2" (no convert) for float data types.
The code below comes from S7nodaveAiRecord.h of s7nodave (https://oss.aquenos.com/epics/s7nodave/ )
The comments have mode details.
    virtual long processRecord()
        long status = S7nodaveInputRecord::processRecord();
        if (status == RECORD_STATUS_OK) {
            // If the PLC is using the float data-type, we do not want the
            // VAL field of this record to be overwritten with a value
            // calculated using the RVAL field. Instead we use the VAL field
            // directly. We signal this to the record's readValue routine by
            // returning the special value RECORD_STATUS_OK_NO_CONVERT instead
            // of RECORD_STATUS_OK.
            if (this->recordAddress->getPlcDataType() == plcDataTypeFloat) {
                return RECORD_STATUS_OK_NO_CONVERT;
            } else {
                return RECORD_STATUS_OK;
        } else {
            return status;
Cheers,
Ronaldo
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Ben Franksen via Tech-talk
Sent: 17 September 2020 16:02
To: [email protected]
Subject: Re: ASLO doesn't work
Am 17.09.20 um 11:10 schrieb Vishnu Patel via Tech-talk:
> I have tried to divide the value of ai record using ASLO field. But It doesn't work.
> record(ai, "AI0") {
>     field(DTYP,"s7nodave")
>     field(INP,"@lcpcPLC DB6.DBD36 float")
>     field(LINR,"LINEAR")
>     field(HOPR,"20")
>     field(LOPR,"0")
>     field(ASLO,"0.001")
>     field(PREC,"4")
>     field(SCAN,"1 second")
>     field(EGU,"Bar")
>     field(EGUF,"32767")
>     field(EGUL,"-32768")
None of the replies so far have offered an explanation of exactly /why/ this doesn't work. Judging from the aiRecord.c code and the format of the INP link, I venture that the device support indicates to the record support that it already did the conversion and wrote the VAL field by returning 2 instead of 0 from its read() method. To teh record support this indicates that it should completely ignore all conversion related fields (RVAL, LINR, EGUF, EGUL, ASLO, AOFF, ESLO, EOFF, ROFF).
Cheers
Ben
ASLO doesn't work Vishnu Patel via Tech-talk
Re: ASLO doesn't work Ben Franksen via Tech-talk
Prev: Re: ASLO doesn't work Ben Franksen via Tech-talk
Next: Re: ASLO doesn't work 李刚 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
