1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: ASLO doesn't work
To: "vishnu patel" <[email protected]>
Date: Fri, 18 Sep 2020 00:27:03 +0800 (GMT+08:00)
Hi Vishnu
If DB6.DBD36 is not float,you must set DLV and DHV in INP field,and discard "float" parameter.
record(ai, "AI0") {
    field(DTYP,"s7nodave")
    field(INP,"@lcpcPLC(DLV=0,DHV=27648) DB6.DBD36 ")
    field(LINR,"LINEAR")
    field(HOPR,"20")
    field(LOPR,"0")
    #field(ASLO,"0.001")
    field(PREC,"4")
    field(SCAN,"1 second")
    field(EGU,"Bar")
    field(EGUF,"20")
    field(EGUL,"0")
If DB6.DBD36 is float and you set explicit in INP field  ,it will ignore all conversion just as Ben said
record(ai, "AI0") {
    field(INP,"@lcpcPLC DB6.DBD36 float ")
    field(HOPR,"20")
    field(LOPR,"0")
    field(PREC,"4")
    field(EGU,"Bar")
    field(EGUF,"20")
    field(EGUL,"0")
Cheers
Gang
-----原始邮件-----
发件人:"Vishnu Patel via Tech-talk" <[email protected]>
发送时间:2020-09-17 17:10:28 (星期四)
收件人: "[email protected]" <[email protected]>
抄送:
主题: ASLO doesn't work
I have tried to divide the value of ai record using ASLO field. But It doesn't work.
record(ai, "AI0") {
    field(INP,"@lcpcPLC DB6.DBD36 float")
    field(HOPR,"20")
    field(LOPR,"0")
    field(ASLO,"0.001")
    field(PREC,"4")
    field(EGU,"Bar")
    field(EGUF,"32767")
    field(EGUL,"-32768")
my input is 1003.124 and it gives same only even i change ASLO to 1.
The PLC the value is 1003.124 in mBar, i have to display as 1.0031 Bar.
I am missing something to set.
Thanks
Vishnu
Re: ASLO doesn't work Vishnu Patel via Tech-talk
Prev: RE: ASLO doesn't work Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: device support for IK342 Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: ASLO doesn't work Vishnu Patel via Tech-talk
