1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: How to build MEDM (Jetson nano)
From: Hinko Kocevar via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: 신동호 <[email protected]>, EPICS tech-talk <[email protected]>
Date: Tue, 22 Sep 2020 16:53:37 +0000
> By ‘native’ I mean this is a build on the linux-aarch64 processor itself which isrunning Ubuntu, it’s not a cross-compile at all. I only just added the native CONFIG files for linux-aarch64 to the Base-7.0 branch when Dong Ho asked about this a week or two ago.
Did not notice the native/cross compile statement anywhere, maybe I have not searched too well for it.
I did realize that native build might be expected, albeit too late, after sending the email.
Nevertheless, I managed to plow through the epics-base + a camonitor extension being cross compiled when I realized that the medm would require whole bunch of X11 stuff that aarch64 cross compile toolchain does not have. It is been a while I did some cross compiling as you can tell.
> If you configured extensions to be cross-compiled on the same Ubuntu release  maybe all the X11 and Motif header files would be the same for the cross-target if you could install them, but the build-time library paths would be different so you wouldn’t be able to test the native CONFIG_SITE files yourself. I’m not too sure whether this is worth doing.
Agree, going native would be a way to test the aarch64 target. I would need to get a hold of the aarch64 libs to get the cross compile through. One way of getting that on a PC would be to find a aarch64 rootfs that has X11 on it and then mount on loop in Linux and point cross compilation tools to look for aarch64 files there. There might still be an issue doing cross compile when it comes to library paths, if they are linked into the shared objects, IIRC EPICS does that, right?
> I asked my boss if I can buy an aarch64 box (an R.Pi-4) to test out this kind of thing, but he hasn’t said yes yet (and I suspect there are a few other R.Pi enthusiasts here who might be quicker at setting this up than I would given everything else I’m supposed to be working on).
I have a RPI4 somewhere. The thing is, as I managed to ddg so far, is that the stock Rpi4 image is 32bit, and not aarch64, AFAICT. There are some other distros like arch, opensuse, fedora that provide aarch4 builds/images. Which one to use?
//hinko
- Andrew
From: Tech-talk <[email protected]<mailto:[email protected]>> on behalf of Johnson, Andrew N. via Tech-talk <[email protected]<mailto:[email protected]>>
Sent: Tuesday, September 22, 2020 4:44:20 AM
To: Rivers, Mark L.
Cc: EPICS tech-talk; 신동호
Unfortunately there is no CONFIG_SITE.linux-aarch64.linux-aarch64 file in the extensions/configure/os directory; Dong Ho is the first person to use this host architecture (which is the 64-bit version of linux-arm and has only just been added to Base) and I suspect may have some difficulties.
My first instinct would be to copy the CONFIG_SITE.linux-x86.linux-x86 file to the name given above and edit it to match, but there are quite a lot of old and irrelevant paths in that file. I suspect the configuration for Ubuntu on linux-aarch64 would be closer to that of linux-x86_64, but the latter file just pulls in and overrides the settings from the 32-bit linux-x86 target. Maybe that would still work though.
I wish I had time to help, but I don't. The whole extensions build area could use cleaning up or replacing, but someone will have to volunteer to take that on, anyone interested?
- Andrew
On Sep 21, 2020, at 8:43 PM, Mark Rivers via Tech-talk <[email protected]<mailto:[email protected]><mailto:[email protected]>> wrote:
CONFIG_SITE is meant to be locally edited for your site. Just make the changes you need for your arch.
If you get build errors post them here.
Sent from my iPhone
On Sep 21, 2020, at 8:31 PM, 신동호 <[email protected]<mailto:[email protected]><mailto:[email protected]>> wrote:
Hi, Mark
I followed the instruction you gave.
To build medm, CONFIGURE_SITE* file for linux-aarch64 is needed.
But I didn't find in the directory ../configure/os.
I guess most extensions for EPICS do not support aarch64.
- Dong Ho, SHIN
-----Original Message-----
From:  "Mark Rivers" <[email protected]<mailto:[email protected]><mailto:[email protected]>>
To:     "신동호" <[email protected]<mailto:[email protected]><mailto:[email protected]>>;
Cc:     "[email protected]<mailto:[email protected]><mailto:[email protected]>" <[email protected]<mailto:[email protected]><mailto:[email protected]>>;
Sent:  2020-09-21 (월) 21:20:06 (UTC+09:00)
First download this module:
https://github.com/epics-extensions/extensions
Then cd to that directory, and in that directory install this module:
https://github.com/epics-extensions/medm
The extensions/README explains how to build it.
https://github.com/epics-extensions/extensions/blob/master/README
From: Tech-talk <[email protected]> on behalf of 신동호 via Tech-talk <[email protected]>
Sent: Monday, September 21, 2020 4:00 AM
To: [email protected]
Subject: How to build MEDM (Jetson nano)
Dear all,
I have succeeded to install EPICS base (Rver 7) with aysn & streamdevice supports.
And now I want to get install GUI tool, MEDM. Would you explain more detail how to build MEDM?
- Dong Ho, SHIN
[https://gov-dooray.com/mail-receipts?img=3768747754637167-255f3328d91a814f-2764576884bb5a9c-27645b06ab92d51d.gif]
Complexity comes for free, simplicity you have to work for.
Re: How to build MEDM (Jetson nano) Johnson, Andrew N. via Tech-talk
How to build MEDM (Jetson nano) 신동호 via Tech-talk
Re: How to build MEDM (Jetson nano) Mark Rivers via Tech-talk
RE: Re: How to build MEDM (Jetson nano) 신동호 via Tech-talk
Re: How to build MEDM (Jetson nano) Hinko Kocevar via Tech-talk
Prev: Re: How to build MEDM (Jetson nano) Johnson, Andrew N. via Tech-talk
Next: Re: How to build MEDM (Jetson nano) Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
