I've managed to compile the medm on RPi4 running aarch64 Ubuntu Desktop image from https://github.com/TheRemote/Ubuntu-Server-raspi4-unofficial/releases.
EPICS extensions configure/os/CONFIG_SITE.linux-aarch64.linux-aarch64 looks like this:
X11_LIB=/usr/lib/aarch64-linux-gnu
X11_INC=/usr/include/X11
MOTIF_LIB=/home/ubuntu/lesstif/lib
MOTIF_INC=/home/ubuntu/lesstif/include
I had to build lesstif manually, hence the weird MOTIF_LIB/MOTIF_INC location, since there is no up to date deb packages of it these days.
PR https://github.com/epics-extensions/extensions/pull/3 has the change.
I also have some notes on the steps on how I performed the whole process, I can share them if some needs them.
//hinko
Sent: Tuesday, September 22, 2020 7:28:45 PM
To: Hinko Kocevar
Cc: EPICS tech-talk; 신동호
Subject: Re: How to build MEDM (Jetson nano)
On Sep 22, 2020, at 11:53 AM, Hinko Kocevar <[email protected]<mailto:[email protected]>> wrote:
If you configured extensions to be cross-compiled on the same Ubuntu release maybe all the X11 and Motif header files would be the same for the cross-target if you could install them, but the build-time library paths would be different so you wouldn’t be able to test the native CONFIG_SITE files yourself. I’m not too sure whether this is worth doing.
Agree, going native would be a way to test the aarch64 target. I would need to get a hold of the aarch64 libs to get the cross compile through. One way of getting that on a PC would be to find a aarch64 rootfs that has X11 on it and then mount on loop in Linux and point cross compilation tools to look for aarch64 files there. There might still be an issue doing cross compile when it comes to library paths, if they are linked into the shared objects, IIRC EPICS does that, right?
EPICS can be configured to not build in library paths, or now to only build in relative paths (using the $ORIGIN feature available in some linkers).
I asked my boss if I can buy an aarch64 box (an R.Pi-4) to test out this kind of thing, but he hasn’t said yes yet (and I suspect there are a few other R.Pi enthusiasts here who might be quicker at setting this up than I would given everything else I’m supposed to be working on).
I have a RPI4 somewhere. The thing is, as I managed to ddg so far, is that the stock Rpi4 image is 32bit, and not aarch64, AFAICT. There are some other distros like arch, opensuse, fedora that provide aarch4 builds/images. Which one to use?
The arch itself might not matter too much, I would hope that the native build-time paths would be the same for the same distro as long as both CPUs are 64-bit, so the paths for Ubuntu on x86_64 would be the same on aarch-64. Maybe we can just create a CONFIG_SITE.linux-aarch64.linux-aarch64 file for Dong Ho to try based on that assumption and see if it works. I’m reluctant to do it myself though since the x86_64 file includes the x86 file which has all sorts of extraneous and inappropriate paths in it so it would be better to manually combine the two into one file and throw out all the extra stuff, and I don’t have time to work on that.
Longer-term I’d like us to get away from the extensions build structure completely and have each GUI program build stand-alone just like any other IOC module. Configuring all the build paths to the X11 and Motif headers for multiple programs could be done in a common module that exports suitable cfg/CONFIG* files, and sites that want to install these programs into a common bin/<host-arch> directory can do that by just setting INSTALL_LOCATION in the module’s CONFIG_SITE file.
- Andrew
From: Tech-talk <[email protected]<mailto:[email protected]><mailto:[email protected]>> on behalf of Johnson, Andrew N. via Tech-talk <[email protected]<mailto:[email protected]><mailto:[email protected]>>
Sent: Tuesday, September 22, 2020 4:44:20 AM
To: Rivers, Mark L.
Unfortunately there is no CONFIG_SITE.linux-aarch64.linux-aarch64 file in the extensions/configure/os directory; Dong Ho is the first person to use this host architecture (which is the 64-bit version of linux-arm and has only just been added to Base) and I suspect may have some difficulties.
My first instinct would be to copy the CONFIG_SITE.linux-x86.linux-x86 file to the name given above and edit it to match, but there are quite a lot of old and irrelevant paths in that file. I suspect the configuration for Ubuntu on linux-aarch64 would be closer to that of linux-x86_64, but the latter file just pulls in and overrides the settings from the 32-bit linux-x86 target. Maybe that would still work though.
I wish I had time to help, but I don't. The whole extensions build area could use cleaning up or replacing, but someone will have to volunteer to take that on, anyone interested?
- Andrew
On Sep 21, 2020, at 8:43 PM, Mark Rivers via Tech-talk <[email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>> wrote:
CONFIG_SITE is meant to be locally edited for your site. Just make the changes you need for your arch.
If you get build errors post them here.
Sent from my iPhone
On Sep 21, 2020, at 8:31 PM, 신동호 <[email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>> wrote:
Hi, Mark
I followed the instruction you gave.
To build medm, CONFIGURE_SITE* file for linux-aarch64 is needed.
But I didn't find in the directory ../configure/os.
I guess most extensions for EPICS do not support aarch64.
- Dong Ho, SHIN
-----Original Message-----
From: "Mark Rivers" <[email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>>
To: "신동호" <[email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>>;
Cc: "[email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>" <[email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>>;
Sent: 2020-09-21 (월) 21:20:06 (UTC+09:00)
First download this module:
Then cd to that directory, and in that directory install this module:
https://github.com/epics-extensions/medm
The extensions/README explains how to build it.
https://github.com/epics-extensions/extensions/blob/master/README
From: Tech-talk <[email protected]> on behalf of 신동호 via Tech-talk <[email protected]>
Sent: Monday, September 21, 2020 4:00 AM
To: [email protected]
Subject: How to build MEDM (Jetson nano)
Dear all,
I have succeeded to install EPICS base (Rver 7) with aysn & streamdevice supports.
And now I want to get install GUI tool, MEDM. Would you explain more detail how to build MEDM?
- Dong Ho, SHIN
[https://gov-dooray.com/mail-receipts?img=3768747754637167-255f3328d91a814f-2764576884bb5a9c-27645b06ab92d51d.gif]
Complexity comes for free, simplicity you have to work for.
Description: Screenshot_2020-09-22_21-30-21.png
- How to build MEDM (Jetson nano) 신동호 via Tech-talk
- Re: How to build MEDM (Jetson nano) Mark Rivers via Tech-talk
- RE: Re: How to build MEDM (Jetson nano) 신동호 via Tech-talk
- Re: How to build MEDM (Jetson nano) Johnson, Andrew N. via Tech-talk
- Re: How to build MEDM (Jetson nano) Hinko Kocevar via Tech-talk
Re: RE: How to build MEDM (Jetson nano) Hinko Kocevar via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
