Subject: Re: StreamDevice "type punning" floating point conversion
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Eric Norum <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 24 Sep 2020 17:19:15 +0000
Hi Eric,
On Sep 24, 2020, at 11:34 AM, Eric Norum <[email protected]> wrote:
I have a piece of equipment that returns an IEEE-754 floating point value expressed as a hexadecimal integer.  i.e. when the device returns the ASCII string
0xbff9d411
it is sending the value
-1.95178
So far the only way I can figure out how to handle this is to read the value into a ai record RVAL then use a subroutine record with a C union to do the conversion and then store the float value in the ai record VAL.  Is there a way to avoid the subroutine record?   I’m looking for sort of a combination of a %x and a %R StreamDevice format converter.
It sounds to me like you need another StreamDevice format converter, which would seem to be the logical place to put this functionality. It’s possible that some devices might need really obscure things like byte-swapping the value in between parsing the hex format integer and writing the 32-bit float value, but hopefully those kinds of devices are so rare that Dirk shouldn’t need to support them until asked.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: StreamDevice "type punning" floating point conversion Brown, Garth via Tech-talk
Re: StreamDevice "type punning" floating point conversion Eric Norum via Tech-talk
Prev: StreamDevice "type punning" floating point conversion Eric Norum via Tech-talk
Next: Re: StreamDevice "type punning" floating point conversion Brown, Garth via Tech-talk
