Subject: StreamDevice "type punning" floating point conversion
To: "[email protected] ([email protected])" <[email protected]>
Date: Thu, 24 Sep 2020 09:34:46 -0700
I have a piece of equipment that returns an IEEE-754 floating point value expressed as a hexadecimal integer.  i.e. when the device returns the ASCII string
	0xbff9d411
it is sending the value
	-1.95178
So far the only way I can figure out how to handle this is to read the value into a ai record RVAL then use a subroutine record with a C union to do the conversion and then store the float value in the ai record VAL.  Is there a way to avoid the subroutine record?   I’m looking for sort of a combination of a %x and a %R StreamDevice format converter.
Eric Norum
[email protected]
Re: StreamDevice "type punning" floating point conversion Johnson, Andrew N. via Tech-talk
Prev: Re: EPICS QT question Mark Rivers via Tech-talk
Next: Re: StreamDevice "type punning" floating point conversion Johnson, Andrew N. via Tech-talk
