Subject: Re: EPICS QT question
To: Jörn Dreyer <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 25 Sep 2020 14:06:41 +0000
What is your image size, datatype, and frame rate?  How many FFTs do you need to do per second?
Sent: Friday, September 25, 2020 1:44 AM
To: [email protected]; Mark Rivers
Hi Mark,
thanks for the tips. I will give that a try. The first step is to do an FFT on the image data.
Am Donnerstag, 24. September 2020, 18:29:07 CEST schrieb Mark Rivers:
> Hi Jörn,
> > One solution would be to implement all the magic math we use as plugins
> > for areaDetector
> > and combine them to the necessary chain.
> > But the machine we use to read the camera is not powerful enough (Odroid
> > XU1) to do that.
> > What would be the performance if we would run the plugins on a separate
> > machine?
> What you propose is quite reasonable.  The camera IOC would need to run the
> NDPluginPva, which is quite efficient.  Here is a screen shot where it is
> processing 784 frames/s of 1024x1024 Float32 images = 3.2 GB/s.
> [cid:[email protected]]
> You can then run an IOC on a more powerful machine with the pvaDriver.  Here
> is a screen shot when it is processing 303 frame/s of 1024x1024 Float32
> images = 1.2 GB/s.
> Of course you need to make sure the network link between the machines can
> handle the required bandwidth.
> > And how to make sure that they all are in sync?
> Can you explain what you mean by that?
I would need to make sure that all the post processed images are based on the live image that is displayed. I guess that if one of the processes takes some time (more time then the trigger rate of the camera) EPICS-QT will update the live image before the post process is finished and the data displayed. The reason is, that we want to store all the data in a common file at the end..
Jörn
> Mark
> ________________________________
> From: Tech-talk <[email protected]> on behalf of Jörn Dreyer via
> Tech-talk <[email protected]> Sent: Thursday, September 24, 2020 8:53
> AM
> Subject: EPICS QT question
> Hi,
> I'm currently developing an application based on EPICS QT. This toolkit
> makes things so much easier than using PyQwt which I have used before for
> the first version of the app. The app reads a picture from a camera,
> displays the original and does some processing of the image like
> fouriertransforms,  peak finding and fitting etc.
> To make sure the analyzed pictures and the camera image are in sync, I
> wanted to read the image data from a PvaClient and display it in an
> QEImage.Then do all the math and display the results in other QEImage
> widgets.
> But unfortunately the set(Pva)Image function is private.
> One solution would be to implement all the magic math we use as plugins for
> areaDetector and combine them to the necessary chain. But the machine we
> use to read the camera is not powerful enough (Odroid XU1) to do that. What
> would be the performance if we would run the plugins on a separate machine?
> Are there any experiences with such a scenario?
> Regards
> Jörn Dreyer
EPICS QT question Jörn Dreyer via Tech-talk
Re: EPICS QT question Mark Rivers via Tech-talk
Re: EPICS QT question Jörn Dreyer via Tech-talk
Prev: RE: RE: How to build MEDM (Jetson nano) 신동호 via Tech-talk
Next: Re: ADProsilica crashing on RHEL7 3.10.0-1127 Dunning, Michael via Tech-talk
Prev: Re: EPICS QT question Jörn Dreyer via Tech-talk
Next: StreamDevice "type punning" floating point conversion Eric Norum via Tech-talk
