Hi Mark, thanks for the tips. I will give that a try. The first step is to do an FFT on the image data. Am Donnerstag, 24. September 2020, 18:29:07 CEST schrieb Mark Rivers: > Hi J� > > > One solution would be to implement all the magic math we use as plugins > > for areaDetector > > > > and combine them to the necessary chain. > > > > But the machine we use to read the camera is not powerful enough (Odroid > > XU1) to do that. > > > > What would be the performance if we would run the plugins on a separate > > machine? > What you propose is quite reasonable. The camera IOC would need to run the > NDPluginPva, which is quite efficient. Here is a screen shot where it is > processing 784 frames/s of 1024x1024 Float32 images = 3.2 GB/s. > > [cid:[email protected]] > > You can then run an IOC on a more powerful machine with the pvaDriver. Here > is a screen shot when it is processing 303 frame/s of 1024x1024 Float32 > images = 1.2 GB/s. > > [cid:[email protected]] > > Of course you need to make sure the network link between the machines can > handle the required bandwidth. > > And how to make sure that they all are in sync? > > Can you explain what you mean by that? I would need to make sure that all the post processed images are based on the live image that is displayed. I guess that if one of the processes takes some time (more time then the trigger rate of the camera) EPICS-QT will update the live image before the post process is finished and the data displayed. The reason is, that we want to store all the data in a common file at the end.. J�/p>
> > Mark > > ________________________________ > From: Tech-talk <[email protected]> on behalf of J�Dreyer via > Tech-talk <[email protected]> Sent: Thursday, September 24, 2020 8:53 > AM > To: [email protected] > Subject: EPICS QT question > > > Hi, > > > I'm currently developing an application based on EPICS QT. This toolkit > makes things so much easier than using PyQwt which I have used before for > the first version of the app. The app reads a picture from a camera, > displays the original and does some processing of the image like > fouriertransforms, peak finding and fitting etc. > > > To make sure the analyzed pictures and the camera image are in sync, I > wanted to read the image data from a PvaClient and display it in an > QEImage.Then do all the math and display the results in other QEImage > widgets. > > But unfortunately the set(Pva)Image function is private. > > > One solution would be to implement all the magic math we use as plugins for > areaDetector and combine them to the necessary chain. But the machine we > use to read the camera is not powerful enough (Odroid XU1) to do that. What > would be the performance if we would run the plugins on a separate machine? > And how to make sure that they all are in sync? > > > Are there any experiences with such a scenario? > > > Regards > > > J�Dreyer
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
