1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: RE: How to build MEDM (Jetson nano)
To: "Johnson, Andrew N." <[email protected]>, Torsten Bögershausen <[email protected]>, "[email protected]" <[email protected]>, Hinko Kocevar <[email protected]>
Date: Fri, 25 Sep 2020 18:02:59 +0900 (KST)
StripTool on RPi2 was successful.
1. /extensions/src/git clone  https://github.com/epics-extensions/StripTool
2. /extensions/src/make
After make completed, the two directories (O.Common & O.linux-arm) created in the /extenstions/src/StripTool.
3. I could find command 'StripTool' in the /extensions/src/StripTool/O.linux-arm
MEDM will be the next .
- Dong Ho, SHIN
-----Original Message-----
To:     "신동호" <[email protected]>;  "Johnson, Andrew N." <[email protected]>;  "Torsten Bögershausen" <[email protected]>;  "[email protected]" <[email protected]>;
Cc:
Sent:  2020-09-23 (수) 16:28:45 (UTC+09:00)
Subject: Re: RE: How to build MEDM (Jetson nano)
> There's no configuration file or something else in the StripTool directory.
How to build or install StripTool?
It is the same as you would need for medm; both use the same toolkit. You need to have the X11 and Motif libraries, then EPICS base and extensions as discussed so far, and finally proceed with compiling striptool.
Jetson nano (which I just realized is a NVIDIA dev board)  looks like complete opposite of the RPi2 in terms of HW ; I wonder what kind of performance you will be able to get out of the RPi2. Going with RPi2 will not remove the need of manually building lesstif, I had to do it for x86_64, aarch-64 and I doubt there exists deb package for arm (that is not from 2012).
If you are able to switch boards, then go with newer RPi and just use 32 bit environment. Still need to manually build lesstif, though.
At the current state of affairs with EPICS base/extensions (assuming Jetson nano has a rootfs with X11 [1]) it seems to me that going with any of the above architectures is viable, and effort imposed is comparable. IOW, no big hurdles either path one takes. I have notes on getting the lesstif built for x86_64 and aarch64 as of yesterday if you need.
IMHO, there might be several different issues we are tackling at once here; new platform, old toolkit, old tools, old build infrastructure that could use rework. None of these are something that one with little time an possibly no prior experience in EPICS can tackle in a sensible time. I'm not saying it is impossible.
//hinko
[1] https://developer.nvidia.com/embedded/dlc/r32-3-1_Release_v1.0/t210ref_release_aarch64/Tegra_Linux_Sample-Root-Filesystem_R32.3.1_aarch64.tbz2
PS.: I have to blurp this out; this story makes makes me seriously start looking into developing striptool replacement that uses modern graphics and lightweight toolkits (! Qt), and is C(++) based; something with Dear ImGui.. and yes, I did notice the 2018 thead about this.
From: [email protected] <[email protected]> on behalf of 신동호 <[email protected]>
Sent: Wednesday, September 23, 2020 8:38 AM
To: Hinko Kocevar; Johnson, Andrew N.; Torsten Bögershausen
With Jestson nano, it's an uneasy feat to build extensions on epics base.
More sophisticated information and knowledge are needed at least for me.
And I have no enough time to do so I changed the computing environment into RPi2, and old version of raspberry pi.
For now, it would be better to use StripTool rather than MEDM.
I've downloaded StripTool source from Github and located under the extensions/src directory.
Dong Ho, SHIN
To:     "Hinko Kocevar" <[email protected]>;  "Johnson, Andrew N." <[email protected]>;
Cc:     "신동호" <[email protected]>;
Sent:  2020-09-23 (수) 14:38:09 (UTC+09:00)
Subject: RE: How to build MEDM (Jetson nano)
Reading this conversation, I feel that there are 2 improvements
that needs a review, comments, and get may be merged:
https://github.com/epics-extensions/extensions/pulls
Re-writing the make structure completely is probably a good goal,
but until we are there, should we try to improve the existing one ?
I don't know.
From: Tech-talk <[email protected]> On Behalf Of Hinko Kocevar via Tech-talk
Sent: Tuesday, September 22, 2020 23:58
To: Johnson, Andrew N. <[email protected]>
Cc: 신동호 <[email protected]>; EPICS tech-talk <[email protected]>
Subject: Re: How to build MEDM (Jetson nano)
I've managed to compile the medm on RPi4 running aarch64 Ubuntu Desktop image from https://github.com/TheRemote/Ubuntu-Server-raspi4-unofficial/releases.
EPICS extensions configure/os/CONFIG_SITE.linux-aarch64.linux-aarch64 looks like this:
X11_LIB=/usr/lib/aarch64-linux-gnu
X11_INC=/usr/include/X11
MOTIF_LIB=/home/ubuntu/lesstif/lib
MOTIF_INC=/home/ubuntu/lesstif/include
I had to build lesstif manually, hence the weird MOTIF_LIB/MOTIF_INC location, since there is no up to date deb packages of it these days.
PR https://github.com/epics-extensions/extensions/pull/3 has the change.
I also have some notes on the steps on how I performed the whole process, I can share them if some needs them.
//hinko
Sent: Tuesday, September 22, 2020 7:28:45 PM
To: Hinko Kocevar
Cc: EPICS tech-talk; 신동호
On Sep 22, 2020, at 11:53 AM, Hinko Kocevar <[email protected]<mailto:[email protected]>> wrote:
If you configured extensions to be cross-compiled on the same Ubuntu release  maybe all the X11 and Motif header files would be the same for the cross-target if you could install them, but the build-time library paths would be different so you wouldn’t be able to test the native CONFIG_SITE files yourself. I’m not too sure whether this is worth doing.
Agree, going native would be a way to test the aarch64 target. I would need to get a hold of the aarch64 libs to get the cross compile through. One way of getting that on a PC would be to find a aarch64 rootfs that has X11 on it and then mount on loop in Linux and point cross compilation tools to look for aarch64 files there. There might still be an issue doing cross compile when it comes to library paths, if they are linked into the shared objects, IIRC EPICS does that, right?
EPICS can be configured to not build in library paths, or now to only build in relative paths (using the $ORIGIN feature available in some linkers).
I asked my boss if I can buy an aarch64 box (an R.Pi-4) to test out this kind of thing, but he hasn’t said yes yet (and I suspect there are a few other R.Pi enthusiasts here who might be quicker at setting this up than I would given everything else I’m supposed to be working on).
I have a RPI4 somewhere. The thing is, as I managed to ddg so far, is that the stock Rpi4 image is 32bit, and not aarch64, AFAICT. There are some other distros like arch, opensuse, fedora that provide aarch4 builds/images. Which one to use?
The arch itself might not matter too much, I would hope that the native build-time paths would be the same for the same distro as long as both CPUs are 64-bit, so the paths for Ubuntu on x86_64 would be the same on aarch-64. Maybe we can just create a CONFIG_SITE.linux-aarch64.linux-aarch64 file for Dong Ho to try based on that assumption and see if it works. I’m reluctant to do it myself though since the x86_64 file includes the x86 file which has all sorts of extraneous and inappropriate paths in it so it would be better to manually combine the two into one file and throw out all the extra stuff, and I don’t have time to work on that.
Longer-term I’d like us to get away from the extensions build structure completely and have each GUI program build stand-alone just like any other IOC module. Configuring all the build paths to the X11 and Motif headers for multiple programs could be done in a common module that exports suitable cfg/CONFIG* files, and sites that want to install these programs into a common bin/<host-arch> directory can do that by just setting INSTALL_LOCATION in the module’s CONFIG_SITE file.
- Andrew
From: Tech-talk <[email protected]<mailto:[email protected]><mailto:[email protected]>> on behalf of Johnson, Andrew N. via Tech-talk <[email protected]<mailto:[email protected]><mailto:[email protected]>>
Sent: Tuesday, September 22, 2020 4:44:20 AM
To: Rivers, Mark L.
Unfortunately there is no CONFIG_SITE.linux-aarch64.linux-aarch64 file in the extensions/configure/os directory; Dong Ho is the first person to use this host architecture (which is the 64-bit version of linux-arm and has only just been added to Base) and I suspect may have some difficulties.
My first instinct would be to copy the CONFIG_SITE.linux-x86.linux-x86 file to the name given above and edit it to match, but there are quite a lot of old and irrelevant paths in that file. I suspect the configuration for Ubuntu on linux-aarch64 would be closer to that of linux-x86_64, but the latter file just pulls in and overrides the settings from the 32-bit linux-x86 target. Maybe that would still work though.
I wish I had time to help, but I don't. The whole extensions build area could use cleaning up or replacing, but someone will have to volunteer to take that on, anyone interested?
- Andrew
On Sep 21, 2020, at 8:43 PM, Mark Rivers via Tech-talk <[email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>> wrote:
CONFIG_SITE is meant to be locally edited for your site. Just make the changes you need for your arch.
If you get build errors post them here.
Sent from my iPhone
On Sep 21, 2020, at 8:31 PM, 신동호 <[email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>> wrote:
Hi, Mark
I followed the instruction you gave.
To build medm, CONFIGURE_SITE* file for linux-aarch64 is needed.
But I didn't find in the directory ../configure/os.
I guess most extensions for EPICS do not support aarch64.
- Dong Ho, SHIN
From:  "Mark Rivers" <[email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>>
To:     "신동호" <[email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>>;
Cc:     "[email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>" <[email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]>>;
Sent:  2020-09-21 (월) 21:20:06 (UTC+09:00)
First download this module:
Then cd to that directory, and in that directory install this module:
https://github.com/epics-extensions/medm
The extensions/README explains how to build it.
https://github.com/epics-extensions/extensions/blob/master/README
From: Tech-talk <[email protected]> on behalf of 신동호 via Tech-talk <[email protected]>
Sent: Monday, September 21, 2020 4:00 AM
To: [email protected]
Subject: How to build MEDM (Jetson nano)
Dear all,
I have succeeded to install EPICS base (Rver 7) with aysn & streamdevice supports.
And now I want to get install GUI tool, MEDM. Would you explain more detail how to build MEDM?
- Dong Ho, SHIN
[https://gov-dooray.com/mail-receipts?img=3768747754637167-255f3328d91a814f-2764576884bb5a9c-27645b06ab92d51d.gif]
Complexity comes for free, simplicity you have to work for.
How to build MEDM (Jetson nano) 신동호 via Tech-talk
Re: How to build MEDM (Jetson nano) Mark Rivers via Tech-talk
RE: Re: How to build MEDM (Jetson nano) 신동호 via Tech-talk
Re: How to build MEDM (Jetson nano) Johnson, Andrew N. via Tech-talk
Re: How to build MEDM (Jetson nano) Hinko Kocevar via Tech-talk
Re: RE: How to build MEDM (Jetson nano) Hinko Kocevar via Tech-talk
Prev: Re: EPICS QT question Jörn Dreyer via Tech-talk
Next: Re: EPICS QT question Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: RE: How to build MEDM (Jetson nano) Hinko Kocevar via Tech-talk
Next: autosave 5-10-1 on RTEMS-4.10.2, mount failed Sintschuk, Michael via Tech-talk
