1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Implementing closed loop on EPICS level
From: Guilherme Jovanini Montagner via Tech-talk <[email protected]>
To: "Kevin M. Peterson" <[email protected]>
Date: Wed, 30 Sep 2020 13:13:54 -0300 (BRT)
Hello Kevin!
Thanks a lot!! It worked!
Now I only have a problem that is the virtual encoder channel that I have setup on m11. Apparently EPICS is trying to control this motor, because I got following errors on the PMAC controller on axis 11, and also a DACLimit warning.
Is it possible to disable m11 actuation?
Also, is there a lower limit to my RDBD value? I wanted to get it as low as 600nm
Thanks!
+55 19 99806.9117
+55 19 2517.8911
[email protected]
Labview Certified Developer
----- Mensagem original -----
De: "Kevin M. Peterson" <[email protected]>
Para: "guilherme" <[email protected]>
Cc: "tech-talk" <[email protected]>
Enviadas: Terça-feira, 29 de setembro de 2020 11:36:19
Assunto: Re: Implementing closed loop on EPICS level
You might be able to make it work by doing the following:
1. Set m1's RDBL field to m11.REP
2. Set m1's RRES field to whatever is required to convert between
m11.REP and m1's EGU.
3. Set m1's URIP = Yes and UEIP = No
Kevin
On 9/29/20 8:55 AM, Guilherme Jovanini Montagner wrote:
> Hi Kevin
> Thank you for your response.
> I tried with UEIP = 1, but then it seems to use the motor 1 encoder (which is just the phase value, or open loop value), and not the m11 encoder that I have setup.
> Then it disregards the m11 encoder reading
> +55 19 99806.9117
> +55 19 2517.8911
> [email protected]
Re: Implementing closed loop on EPICS level Guilherme Jovanini Montagner via Tech-talk
Re: Implementing closed loop on EPICS level Peterson, Kevin M. via Tech-talk
Prev: Re: Implementing closed loop on EPICS level Guilherme Jovanini Montagner via Tech-talk
Next: Re: Implementing closed loop on EPICS level Guilherme Jovanini Montagner via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
