Subject: RE: Inconsistency of image rate in ADVimba
To: "'Engbretson, Mark S.'" <[email protected]>, Jong Woo Kim <[email protected]>
Date: Mon, 5 Oct 2020 21:18:41 +0000
>  Is this camera on a shared network cable or on a dedicated private network? Is the ethernet MTU setting (jumbo packets) as large as the ethernet adapter supports?
Note that in my previous post the Manta camera was connected to the public network, and was not using jumbo packets, the packet size was 1500.  It was still able to run at the maximum specified frame rate of 21 frames/s.  That is 2464*2056*21 bytes/s = 106,385,664 bytes/s , which is very close to the maximum bandwidth of 1 Gbit Ethernet, which is what this camera uses.  The camera was connected to the same switch as the computer.
From: Tech-talk <[email protected]> On Behalf Of Engbretson, Mark S. via Tech-talk
Sent: Monday, October 5, 2020 3:41 PM
To: Jong Woo Kim <[email protected]>
Cc: [email protected] ([email protected]) <[email protected]>
Area any errors being thrown in the iocConsole?  Is this camera on a shared network cable or on a dedicated private network? Is the ethernet MTU setting (jumbo packets) as large as the ethernet adapter supports?
From: Tech-talk <[email protected]> On Behalf Of Jong Woo Kim via Tech-talk
Sent: Monday, October 5, 2020 3:32 PM
To: [email protected]
Subject: Inconsistency of image rate in ADVimba
I found that the Image rate (PV:13VMB1:cam1:ArrayRate_RBV) varies randomly.
When I set the Frame rate to be 10 and ROI to be 2464x2056 (full image size), The image rate is sometimes 22 or 2 or 8. There is also no tendency with ROI. The camera is Mako. Do you have any idea about this issue?
Best,
Jong Woo
RE: Inconsistency of image rate in ADVimba Engbretson, Mark S. via Tech-talk
Inconsistency of image rate in ADVimba Jong Woo Kim via Tech-talk
Prev: RE: Inconsistency of image rate in ADVimba Mark Rivers via Tech-talk
Next: RE: Inconsistency of image rate in ADVimba Engbretson, Mark S. via Tech-talk
Prev: RE: Inconsistency of image rate in ADVimba Engbretson, Mark S. via Tech-talk
