Was wondering if since at some points , since it was running at speed, network issues were then dropping down to slower ones. I.e., someone perhaps with multiple GigE cameras on the same network. These are cheap these days, and people are
using them as web cams . . . but still setting the FPS to be fast.
> Is this camera on a shared network cable or on a dedicated private network? Is the ethernet MTU setting (jumbo packets) as large as the ethernet adapter supports?
Note that in my previous post the Manta camera was connected to the public network, and was not using jumbo packets, the packet size was 1500. It was still able to run at the maximum specified frame rate of 21 frames/s. That is 2464*2056*21
bytes/s = 106,385,664 bytes/s , which is very close to the maximum bandwidth of 1 Gbit Ethernet, which is what this camera uses. The camera was connected to the same switch as the computer.
Area any errors being thrown in the iocConsole? Is this camera on a shared network cable or on a dedicated private network? Is the ethernet MTU setting (jumbo packets) as large as the ethernet adapter supports?
On Behalf Of Jong Woo Kim via Tech-talk
Sent: Monday, October 5, 2020 3:32 PM
To: [email protected]
Subject: Inconsistency of image rate in ADVimba
I found that the Image rate (PV:13VMB1:cam1:ArrayRate_RBV) varies randomly.
When I set the Frame rate to be 10 and ROI to be 2464x2056 (full image size), The image rate is sometimes 22 or 2 or 8. There is also no tendency with ROI. The camera is Mako. Do you have any idea
about this issue?
