Subject: Re: How can I use pvapy or p4p to monitor multiple PVS
From: Marty Kraimer via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 13 Oct 2020 06:06:15 -0400
On 10/12/20 11:54 PM, Mark Rivers via Tech-talk wrote:
However, in the process of testing it, it was found that only a single PV can be monitored
In p4p can’t you just call the monitor() method multiple times, once for each PV that you want to monitor?
In pvapy can’t you just create a Channel object for each PV, and call it’s monitor() method?
What Mark said should work.
Note that pvaPy also has methods: subscribe,unsubscribe,startMonitor,stopMonitor.
For example
 |             def echo(x):
 |                  print 'New PV value: ', x
 |              channel = Channel('exampleFloat')
 |              channel.subscribe('echo', echo)
 |              channel.startMonitor()
Marty
Sent from my iPhone
On Oct 12, 2020, at 10:18 PM, 秦天 via Tech-talk <[email protected]@aps.anl.gov <[email protected]@aps.anl.gov> wrote:
Subject: How can I use pvapy or p4p to monitor multiple PVS
To:[email protected]
Date:Tue,13 October 2020
Hi EPICS community, I am trying to monitor several EPICS7 PVs using pvapy or p4p. pvapy and p4p are described below:
http://epics-pvdata.sourceforge.net/docbuild/4.7.0/pvaPy/
https://mdavidsaver.github.io/p4p/
However, in the process of testing it, it was found that only a single PV can be monitored.The method of connecting to multiple PV is multiChannel,but there is only get(),  no monitor method. What method can be used to monitor a large number of PV?
Best regards,
Sky Qin
下载视频
How can I use pvapy or p4p to monitor multiple PVS 秦天 via Tech-talk <[email protected]
Re: How can I use pvapy or p4p to monitor multiple PVS Mark Rivers via Tech-talk
Prev: CS-Studio OPI Views Vishnu Patel via Tech-talk
Next: EPICS timestamp in the archiver appliance Abdalla Ahmad via Tech-talk
Prev: Re: How can I use pvapy or p4p to monitor multiple PVS Mark Rivers via Tech-talk
Next: Re: How can I use pvapy or p4p to monitor multiple PVS Michael Davidsaver via Tech-talk
