Subject: Re: EPICS timestamp in the archiver appliance
From: "Shankar, Murali via Tech-talk" <[email protected]>
To: Abdalla Ahmad <[email protected]>, Mark Rivers <[email protected]>
Date: Tue, 13 Oct 2020 14:15:37 +0000
>> Is there a way to configure the archiver appliance to take the local timestamp instead of the CA one?
Sorry; not at this moment. Without a proper timestamp, the archiver appliance will drop samples.
Murali
Sent: Tuesday, October 13, 2020 5:17 AM
To: Mark Rivers <[email protected]>; Shankar, Murali <[email protected]>
Cc: [email protected] <[email protected]>
Subject: RE: EPICS timestamp in the archiver appliance
Hi Mark
No they are something else, specifically they are Libera devices from I-Tech. For example on the Libera electron I managed to get the NTP working by setting the hardware clock using “hwclock”, writing “/etc/ntp.conf” pointing to our NTP server then running the NTP daemon but the Libera BLM for example can’t set the hardware clock because it can’t find “/dev/rtc”.
We are in talks with I-Tech to solve the issue but I want to know if such configuration can be done on the archiver side. For example, “camonitor –t c” gives you the correct timestamp (local one), so I imagine EPICS somehow can be configured in such manner.
Thanks!
Abdalla.
Sent: Tuesday, October 13, 2020 3:10 PM
To: Abdalla Ahmad <[email protected]>; '[email protected]' <[email protected]>
Are these hard-IOCs vxWorks, RTEMS, or something else?  On vxWorks you should be able to make NTP work.
From: Tech-talk <[email protected]> On Behalf Of Abdalla Ahmad via Tech-talk
Sent: Tuesday, October 13, 2020 7:07 AM
To: [email protected]; [email protected]
Subject: EPICS timestamp in the archiver appliance
Hi
We have an issue when we want to archive PVs from a hard-IOC based device. The issue is that these devices don’t have the time set correctly and most likely somehow NTP won’t work. This causes an issue archiving these PVs because, if I understand correctly, the archiver takes the timestamp from the channel access not the local one. Is there a way to configure the archiver appliance to take the local timestamp instead of the CA one?
Best Regards,
Abdalla.
Re: EPICS timestamp in the archiver appliance Brown, Garth via Tech-talk
EPICS timestamp in the archiver appliance Abdalla Ahmad via Tech-talk
RE: EPICS timestamp in the archiver appliance Mark Rivers via Tech-talk
RE: EPICS timestamp in the archiver appliance Abdalla Ahmad via Tech-talk
Prev: Re: How can I use pvapy or p4p to monitor multiple PVS 秦天 via Tech-talk <[email protected]
Next: Re: How can I use pvapy or p4p to monitor multiple PVS Veseli, Sinisa via Tech-talk
Prev: RE: EPICS timestamp in the archiver appliance Abdalla Ahmad via Tech-talk
Next: Re: EPICS timestamp in the archiver appliance Brown, Garth via Tech-talk
