If you can tolerate a small inaccuracy in the time stamps, and you have PVs on a different device with proper time stamps updating about the same rate, you could work around this by using the .TSEL field. Make the .TSEL field of PVs on the device with inaccurate
time a link to the .TIME field of a PV on the device with accurate time, and you'll get time stamps accurate to within the scan rate of the PV on the device with accurate time.
Garth
>> Is there a way to configure the archiver appliance to take the local timestamp instead of the CA one?
Sorry; not at this moment. Without a proper timestamp, the archiver appliance will drop samples.
Murali
Hi Mark
No they are something else, specifically they are Libera devices from I-Tech. For example on the Libera electron I managed to get the NTP working by setting the hardware clock using “hwclock”, writing “/etc/ntp.conf”
pointing to our NTP server then running the NTP daemon but the Libera BLM for example can’t set the hardware clock because it can’t find “/dev/rtc”.
We are in talks with I-Tech to solve the issue but I want to know if such configuration can be done on the archiver side. For example, “camonitor –t c” gives you the correct timestamp (local one), so I imagine
EPICS somehow can be configured in such manner.
Thanks!
Abdalla.
Are these hard-IOCs vxWorks, RTEMS, or something else? On vxWorks you should be able to make NTP work.
Hi
We have an issue when we want to archive PVs from a hard-IOC based device. The issue is that these devices don’t have the time set correctly and most likely somehow NTP won’t work. This causes an issue archiving these PVs because, if
I understand correctly, the archiver takes the timestamp from the channel access not the local one. Is there a way to configure the archiver appliance to take the local timestamp instead of the CA one?
Best Regards,
Abdalla.
- Re: EPICS timestamp in the archiver appliance Abdalla Ahmad via Tech-talk
- EPICS timestamp in the archiver appliance Abdalla Ahmad via Tech-talk
- RE: EPICS timestamp in the archiver appliance Mark Rivers via Tech-talk
- RE: EPICS timestamp in the archiver appliance Abdalla Ahmad via Tech-talk
- Re: EPICS timestamp in the archiver appliance Shankar, Murali via Tech-talk
Re: How can I use pvapy or p4p to monitor multiple PVS Veseli, Sinisa via Tech-talk
Re: How can I use pvapy or p4p to monitor multiple PVS Michael Davidsaver via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
