Subject: Re: How can I use pvapy or p4p to monitor multiple PVS
From: "Veseli, Sinisa via Tech-talk" <[email protected]>
To: tech-talk <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 13 Oct 2020 14:32:13 +0000
Hello,
Here are the pvapy examples that monitor multiple channels:
The above should work for tens of thousands pv's that update at a rate of 1Hz or so.
Also, the latest pvapy documentation can be found here: https://epics.anl.gov/extensions/pvaPy/production/index.html.
Best Regards,
Sinisa
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
(630)252-9182
From: Tech-talk <[email protected]> on behalf of =?utf-8?b?56em5aSpIHZpYSBUZWNoLXRhbGsgPHRlY2gtdGFsa0BhcHMuYW5sLmdv?=@aps.anl.gov <=?utf-8?b?56em5aSpIHZpYSBUZWNoLXRhbGsgPHRlY2gtdGFsa0BhcHMuYW5sLmdv?=@aps.anl.gov>
Sent: Tuesday, October 13, 2020 7:18 AM
To: Rivers, Mark L. <[email protected]>; Marty Kraimer <[email protected]>; tech-talk <[email protected]>
Thank you for your answer.I've solved my problem.
I need to loop to create an associated class object for each pv.Then use each class object to execute the monitor function.
For example
 |  for i in range(51):
 |	if pvnames[i] == 'xkSun:test50Scalar:aiExample1':
 |          globals()['pv' + str(i)] = pv_monitor(pvnames[i])
 |          globals()['pv' + str(i)].my_monitor()
 |  def my_monitor(self):
 |     ctxt.monitor(self.pv, self.onChanges)
Subject:Re: How can I use pvapy or p4p to monitor multiple PVS
From:Marty Kraimer via Tech-talk <tech-talk at aps.anl.gov>
To:tech-talk at aps.anl.gov
Date:Tue, 13 Oct 2020 06:06:15 -0400
What Mark said should work.
Note that pvaPy also has methods: subscribe,unsubscribe,startMonitor,stopMonitor.
For example
 |             def echo(x):
 |                  print 'New PV value: ', x
 |              channel = Channel('exampleFloat')
 |              channel.subscribe('echo', echo)
 |              channel.startMonitor()
Marty
From:Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To:"qt980319 at mail.ustc.edu.cn" <qt980319 at mail.ustc.edu.cn>
Cc:"sunxk at ustc.edu.cn" <sunxk at ustc.edu.cn>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date:Tue, 13 Oct 2020 03:54:32 +0000
However, in the process of testing it, it was found that only a single PV can be monitored
In p4p can’t you just call the monitor() method multiple times, once for each PV that you want to monitor?
In pvapy can’t you just create a Channel object for each PV, and call it’s monitor() method?
Re: How can I use pvapy or p4p to monitor multiple PVS 秦天 via Tech-talk <[email protected]
Prev: Re: EPICS timestamp in the archiver appliance Shankar, Murali via Tech-talk
Next: Re: EPICS timestamp in the archiver appliance Brown, Garth via Tech-talk
Prev: Re: How can I use pvapy or p4p to monitor multiple PVS 秦天 via Tech-talk <[email protected]
Next: Re: How can I use pvapy or p4p to monitor multiple PVS 秦天 via Tech-talk <[email protected]
