Subject: AW: device support for Newstep NSC200 from Newport
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
Date: Fri, 16 Oct 2020 09:02:04 +0000
Hi Mark,
indeed the command-set of the CONEX-PP looks very similar to the NSC200 command-set. Thanks for the hint! I try to enhance the AG-CONEX driver. If that works, I can push this to git.
Michael
Von: Mark Rivers <[email protected]>
Gesendet: Donnerstag, 15. Oktober 2020 15:56
An: Sintschuk, Michael <[email protected]>
Cc: [email protected]; Igor Kriznar <[email protected]>
Betreff: RE: device support for Newstep NSC200 from Newport
Hi Michael,
I would refer you to this tech-talk thread which is not about the NSC200, but my reply would be the same:
https://epics.anl.gov/tech-talk/2020/msg00690.php
The NSC200 appears to have a similar command set to the AG-CONEX.  There is an EPICS model 3 motor driver that I wrote for that here:
https://github.com/epics-motor/motorNewport/blob/master/newportApp/src/AG_CONEX.cpp
I suspect that you may be able to enhance that driver to also support the NSC200.  If it is too different then you could make a new driver based on it.
My later conversations with Igor were offline from tech-talk, but I think he just modified that AG-Conex driver to also support the DL325.  If so we may be able to merge his version back into the master branch, and you can see how he did it.
From: Tech-talk <[email protected]> On Behalf Of Sintschuk, Michael via Tech-talk
Sent: Thursday, October 15, 2020 7:57 AM
To: EPICS tech-talk <
[email protected]>
Subject: device support for Newstep NSC200 from Newport
Hello all,
does anyone has an EPICS motor driver for the motion controller “NewStep NSC200” from Newport:
https://www.newport.com/medias/sys_master/images/images/he3/h40/8797222567966/NSC200-User-Manual.pdf
Sharing is greatly appreciated!
Best regards
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8104-5736 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected]
device support for Newstep NSC200 from Newport Sintschuk, Michael via Tech-talk
RE: device support for Newstep NSC200 from Newport Mark Rivers via Tech-talk
Prev: AW: caQtDM Testflight (Apple) Brands Helge (PSI) via Tech-talk
Next: Job Opening at Fermilab James F Patrick via Tech-talk
Prev: RE: device support for Newstep NSC200 from Newport Mark Rivers via Tech-talk
Next: VICI universal actuator valves Wyman, Max D via Tech-talk
