Subject: CSS Build error
From: Vishnu Patel via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Wed, 28 Oct 2020 05:19:15 +0000
   I am trying to compile sns-css code from
i have downloaded diirt.
But gives maven-osgi-bundles error
[INFO] org.diirt.p2 ....................................... SUCCESS [ 32.956 s]
[INFO] ------------------------------------------------------------------------
[INFO] BUILD SUCCESS
[INFO] Total time: 02:27 min
[INFO] Finished at: 2020-10-28T10:32:23+05:30
[INFO] Final Memory: 279M/6773M
653.63user 56.78system 2:30.27elapsed 472%CPU (0avgtext+0avgdata 3098396maxresident)k
0inputs+254760outputs (0major+4147920minor)pagefaults 0swaps
test2
make.sh: 64: cd: can't cd to maven-osgi-bundles
[INFO] Scanning for projects...
[INFO] BUILD FAILURE
[INFO] Total time: 0.109 s
[INFO] Finished at: 2020-10-28T10:32:26+05:30
[INFO] Final Memory: 22M/1963M
[ERROR] The goal you specified requires a project to execute but there is no POM in this directory (/home/trainee/eclipse-workspace/cssProj). Please verify you invoked Maven from the correct directory. -> [Help 1]
I have downloaded
and use the  maven-osgi-bundles
it gives error
[INFO] org.diirt.p2 ....................................... SUCCESS [ 32.299 s]
[INFO] Finished at: 2020-10-28T10:43:10+05:30
[INFO] Final Memory: 278M/6712M
662.68user 55.32system 2:30.06elapsed 478%CPU (0avgtext+0avgdata 3096824maxresident)k
0inputs+254760outputs (0major+4208493minor)pagefaults 0swaps
test2
[ERROR] [ERROR] Some problems were encountered while processing the POMs:
[FATAL] Non-resolvable parent POM for org.csstudio:maven-osgi-bundles:[unknown-version]: Could not find artifact org.csstudio:cs-studio:pom:4.6.0-SNAPSHOT and 'parent.relativePath' points at wrong local POM @ line 10, column 11
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR]   The project org.csstudio:maven-osgi-bundles:[unknown-version] (/home/trainee/eclipse-workspace/cssProj/maven-osgi-bundles/pom.xml) has 1 error
[ERROR]     Non-resolvable parent POM for org.csstudio:maven-osgi-bundles:[unknown-version]: Could not find artifact org.csstudio:cs-studio:pom:4.6.0-SNAPSHOT and 'parent.relativePath' points at wrong local POM @ line 10, column 11 -> [Help 2]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/UnresolvableModelException
I am new in the CS-Studio compilation.
Please guide me to compile CS-Studio
Thanks
Vishnu
Prev: Re: Build system prepending $(TOP) to make path on win32-x86 Johnson, Andrew N. via Tech-talk
Next: EPICS IOC and its client application with ONLY IPv6 Jeong Han Lee via Tech-talk
Prev: vscode extension for EPICS Victor Nadot via Tech-talk
