Subject: Re: EPICS How-To , Installation on Windows
From: John Dobbins via Tech-talk <[email protected]>
To: "Akeroyd, Freddie (STFC,RAL,ISIS)" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 2 Nov 2020 22:23:41 +0000
Thanks, I just discovered that the older version I grabbed from gnuwin32 (re2c 0.9.4) doesn't work.
John
From: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>
Sent: Monday, November 2, 2020 5:17 PM
To: John Dobbins <[email protected]>; [email protected] <[email protected]>
Subject: RE: EPICS How-To , Installation on Windows
Hi John,
There are some options for re2c on windows listed at https://www-csr.bessy.de/control/SoftDist/sequencer/Installation.html
Freddie
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: 02 November 2020 20:48
To: [email protected]
I have switched to Visual Studio Community Editon + Strawberry PERL. I was able to build  base 3.15.8 without error.
Is there a recommended way to get re2c on Windows?
John
Sent: Monday, November 2, 2020 2:06 PM
To: Rivers, Mark L. <[email protected]>; John Dobbins <[email protected]>
2019 has worked fine since it came out . . .
From: Tech-talk <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: Monday, November 2, 2020 1:05 PM
To: 'John Dobbins' <[email protected]>
Cc: [email protected]
I believe Community Edition 2019 works fine, though I have only tested up to 2017.  And Strawberry Perl will give you perl and gnumake.
Sent: Monday, November 2, 2020 12:59 PM
Mark,
"I think most Windows users are using Visual Studio and not mingw."
Good to know.  Looking at various pages it wasn't clear what practice is common these days.
Is Community Edition 2019 known to work? This plus Strawberry PERL?
John
Sent: Monday, November 2, 2020 1:48 PM
Cc: [email protected] <[email protected]>
Hi John,
I think most Windows users are using Visual Studio and not mingw.  I have not tested to see how well mingw works with vendor libraries that are compiled with Visual Studio.  I know for sure that Cygwin stopped working with vendor libraries that were compiled with Visual Studio quite a few years ago.
Sent: Monday, November 2, 2020 11:02 AM
Subject: EPICS How-To , Installation on Windows
All,
I am attempting to install EPICS on Windows 10 per the EPICS "How-To"
I encounter the errors shown below.
Note that I am not wedded to this method of installation. (I have installed on Windows before but so infrequently that each time is a new adventure.)
Any advice appreciated.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
../osi/os/WIN32/epicsTempFile.cpp: In function ‘FILE* epicsTempFile()’:
../osi/os/WIN32/epicsTempFile.cpp:33:20: error: ‘_tempnam’ was not declared in this scope; did you mean ‘tempnam’?
   33 |     char * pName = _tempnam ( "c:\\tmp", "epics" );
      |                    tempnam
../osi/os/WIN32/epicsTempFile.cpp:49:26: error: ‘_O_CREAT’ was not declared in this scope; did you mean ‘O_CREAT’?
   49 |     const int openFlag = _O_CREAT | _O_EXCL | _O_RDWR |
      |                          O_CREAT
../osi/os/WIN32/epicsTempFile.cpp:49:37: error: ‘_O_EXCL’ was not declared in this scope; did you mean ‘O_EXCL’?
      |                                     O_EXCL
../osi/os/WIN32/epicsTempFile.cpp:49:47: error: ‘_O_RDWR’ was not declared in this scope; did you mean ‘O_RDWR’?
      |                                               O_RDWR
../osi/os/WIN32/epicsTempFile.cpp:50:9: error: ‘_O_SHORT_LIVED’ was not declared in this scope
   50 |         _O_SHORT_LIVED | _O_BINARY | _O_TEMPORARY;
../osi/os/WIN32/epicsTempFile.cpp:50:26: error: ‘_O_BINARY’ was not declared in this scope; did you mean ‘O_BINARY’?
      |                          O_BINARY
../osi/os/WIN32/epicsTempFile.cpp:50:38: error: ‘_O_TEMPORARY’ was not declared in this scope
../osi/os/WIN32/epicsTempFile.cpp:51:38: error: ‘_S_IWRITE’ was not declared in this scope; did you mean ‘S_IWRITE’?
   51 |     int fd = open ( pName, openFlag, _S_IWRITE );
      |                                      S_IWRITE
../osi/os/WIN32/epicsTempFile.cpp:54:20: error: ‘_fdopen’ was not declared in this scope; did you mean ‘fdopen’?
   54 |         pNewFile = _fdopen ( fd, "w+b" );
      |                    fdopen
../osi/os/WIN32/epicsTempFile.cpp:59:43: error: ‘errno’ was not declared in this scope
   59 |             "\"%s\"\n", pName, strerror ( errno ) );
../osi/os/WIN32/epicsTempFile.cpp:23:1: note: ‘errno’ is defined in header ‘<cerrno>’; did you forget to ‘#include <cerrno>’?
   22 | #include "epicsTempFile.h"
  +++ |+#include <cerrno>
   23 |
Installing PERL_MODULES file ../../../../lib/perl/EPICS/macLib.pm
make[4]: *** No rule to make target 'epicsTempFile.obj', needed by 'antelope.exe'.  Stop.
make[4]: Leaving directory '/home/admin-jad22/base-7.0.3.1/modules/libcom/src/O.windows-x64-mingw'
make[3]: *** [../../../configure/RULES_ARCHS:58: install.windows-x64-mingw] Error 2
make[3]: Leaving directory '/home/admin-jad22/base-7.0.3.1/modules/libcom/src'
make[2]: *** [../../configure/RULES_DIRS:84: src.install] Error 2
make[2]: Leaving directory '/home/admin-jad22/base-7.0.3.1/modules/libcom'
make[1]: *** [../configure/RULES_DIRS:84: libcom.install] Error 2
make[1]: Leaving directory '/home/admin-jad22/base-7.0.3.1/modules'
make: *** [configure/RULES_DIRS:84: modules.install] Error 2
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
EPICS How-To , Installation on Windows John Dobbins via Tech-talk
RE: EPICS How-To , Installation on Windows Mark Rivers via Tech-talk
Re: EPICS How-To , Installation on Windows John Dobbins via Tech-talk
RE: EPICS How-To , Installation on Windows Akeroyd, Freddie (STFC, RAL, ISIS) via Tech-talk
Prev: RE: EPICS How-To , Installation on Windows Akeroyd, Freddie (STFC, RAL, ISIS) via Tech-talk
Next: RE: LabView-EPICS Integration using SoftIoc Akeroyd, Freddie (STFC, RAL, ISIS) via Tech-talk
Next: Re: EPICS How-To , Installation on Windows Ralph Lange via Tech-talk
