Subject: Re: Building ADVimba on Raspberry Pi
From: "Kinder, Steve \(STFC,DL,TECH\) via Tech-talk" <[email protected]>
Date: Wed, 4 Nov 2020 21:31:26 +0000
I haven't done extensive performance tests as yet. The simple tests I have done so far have been to try and achieve reliable performance at 10Hz. To achieve this I've had to use vertical and horizontal binning of 4. With binning of 1 and 2 I get errors like the following:
2020/11/04 21:18:33.203 ADVimba::processFrame error GetReceiveStatus returned 0 frameStatus=-1
I have achieved faster rates but had to reduce the image size further.
I suspect from what limited research I've done that the RPi4's Ethernet interface isn't performing very well.
I haven't tried saving to disk yet. I'm displaying via a Phoebus GUI on a separate Windows system but that doesn't seem to affect the above so far as I can tell.
Hope that helps. If you would like me to run any more specific tests let me know.
Steve
Sent: 04 November 2020 17:49
To: Kinder, Steve (STFC,DL,TECH) <[email protected]>
Cc: [email protected] <[email protected]>
> ADVimba then built and I have been able to get an IOC working using this.
What performance have you been able to obtain with an actual camera?  How many frames/s does it acquire, display in a viewer, and save to disk?
From: Kinder, Steve (STFC,DL,TECH) <[email protected]>
Sent: Wednesday, November 4, 2020 10:43 AM
To: Mark Rivers
Thanks to all for the replies.
I created a vimbaSupportC/os/linux-arm directory and copied in the relevant files from my AVT Vimba_4_0 download. I also added a linux-arm section to vimbaSupportC/Makefile. ADVimba then built and I have been able to get an IOC working using this.
Steve
Sent: 28 October 2020 17:21
Hi Steve,
ADVimba does not come with the libVimbaC.so, etc. files for linux-arm.  But those library  files are available from AVT, so you could copy them over and it should build.  If it works we could add them to the distribution.
From: Tech-talk <[email protected]> on behalf of Kinder, Steve (STFC,DL,TECH) via Tech-talk <[email protected]>
Sent: Wednesday, October 28, 2020 11:59 AM
To: EPICS Tech Talk
Subject: Building ADVimba on Raspberry Pi
I get the following error when trying to build ADVimba on a Raspberry Pi. Any suggestions as to how to get around this would be appreciated whilst I continue trying.
Thanks
Steve
/usr/bin/ar -rc    libVimbaCPP.a     AncillaryData.o BaseFeature.o BasicLockable.o BoolFeature.o Camera.o Clock.o CommandFeature.o Condition.o ConditionHelper.o DefaultCameraFactory.o EnumEntry.o EnumFeature.o FeatureContainer.o Feature.o FileLogger.o FloatFeature.o Frame.o FrameHandler.o Interface.o IntFeature.o Mutex.o MutexGuard.o RawFeature.o Semaphore.o StringFeature.o VimbaSystem.o
/usr/bin/ranlib libVimbaCPP.a
make[2]: *** No rule to make target '../../lib/linux-arm/libVimbaC.a', needed by 'libVimbaCPP.so'.  Stop.
make[2]: Leaving directory '/home/controls/prod/R7.0.3.1/support/ADVimba/1-2dl1/vimbaSupportCPP/O.linux-arm'
make[1]: *** [/home/epics/R7.0.3.1/base/configure/RULES_ARCHS:58: install.linux-arm] Error 2
make[1]: Leaving directory '/home/controls/prod/R7.0.3.1/support/ADVimba/1-2dl1/vimbaSupportCPP'
make: *** [/home/epics/R7.0.3.1/base/configure/RULES_DIRS:84: vimbaSupportCPP.install] Error 2
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
Re: Building ADVimba on Raspberry Pi Mark Rivers via Tech-talk
Building ADVimba on Raspberry Pi Kinder, Steve (STFC,DL,TECH) via Tech-talk
Re: Building ADVimba on Raspberry Pi Kinder, Steve (STFC,DL,TECH) via Tech-talk
Prev: Re: Building ADVimba on Raspberry Pi Mark Rivers via Tech-talk
Next: Re: Building ADVimba on Raspberry Pi Mark Rivers via Tech-talk
