1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: read RVB and VAL don't match when moving smarAct motors without encoders
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: "Reinhardt, Juliane" <[email protected]>
Cc: David Shapiro <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 13 Nov 2020 08:31:03 +0000
Juliane,
The MCS and MCS2 controllers have different command sets. That command won't work with the MCS controller.
Kevin
On Nov 13, 2020 1:45 AM, Juliane Reinhardt <[email protected]> wrote:
Hi Kevin,
smarAct does not support the EPICS driver, they did however mention the community-developed drivers that can be found on github. I had a look into this one: https://github.com/epics-motor/motorSmarAct/blob/master/smarActApp/src/smarActMCS2MotorDriver.cpp and found the variable theoryPosition that reads :CHAN%d:POS:TARG
Is that the required command to query a motor without an encoder? Then I could try to build a new IOC based on this package.
Juliane
Prev: Re: read RVB and VAL don't match when moving smarAct motors without encoders Juliane Reinhardt via Tech-talk
Next: Re: Connection to PVA server fails despite server Wlodek, Jakub via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: read RVB and VAL don't match when moving smarAct motors without encoders Kevin Peterson via Tech-talk
Next: New releases of ADGenICam and ADAravis Mark Rivers via Tech-talk
