1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: New releases of ADGenICam and ADAravis
Date: Sun, 15 Nov 2020 17:19:25 +0000
Folks,
ADGenICam R1-7 is now available.  This is from the release notes:
* Added bool leftShift argument to decompressMono12Packed() and decompressMono12p().
  In R1-6 these functions always left shifted the output by 4 bits, and bits 0-3 were 0.
  This 4-bit left-shift operation is now optional.
* Added 3 new FLIR cameras.
Home page: https://github.com/areaDetector/ADGenICam
ADAravis R2-2 is now available.  This is from the release notes:
* Added new ConvertPixelFormat mbbo record with choices of Mono16Low and Mono16High.
  This record controls how Mono12Packed and Mono12p pixel formats are decompressed.
  - Mono16Low means that the data is not left-shifted by 4 bits, so bits 12-15 are 0.
  - Mono16High means that the data is left-shifted by 4 bits, so bits 0-3 are 0.
  This requires ADGenICam R1-7 or later because that contains the code to handle the left-shift option.
* Replaced the LeftShift record with ShiftDir and ShiftBits.
  - ShiftDir selects the direction in which to shift UInt16 data.  Choices are None, Left, and Right.
  - ShiftBits controls the number of bits to shift.  Choices are 1-8.  This record is not used if ShiftDir=None.
  - This change allows complete control over how to shift Mono10, Mono12, and Mono16 pixel formats.
  - For example, FLIR cameras always left-shift Mono16 PixelFormat data so the most-significant bit
    is in bit 15, and the data range is 0-65535, even if the ADC is only 10 or 12 bits.
  - In some cases it may be preferable to right-shift this data so that it only spans the
    actual range of the ADC. In the case of a 12-bit ADC this would be done with ShiftDir=Right and ShiftBits=4.
    The data will then span the range 0-4095.
  - Note that when decompressing Mono12Packed and Mono12p it may still be desirable to
    use ShiftDir and ShiftBits.  For example on FLIR cameras if AdcBitDepth=10 then the data unpacked
    with ConvertPixelFormat=Mono16Low will be 12 bits with a range of 0-4095, with bits 0 and 1 both 0.
    By using ShiftDir=Right and ShiftBits=2 then the data will be truly 10 bits, with a range of 0-1023.
Home page: https://github.com/areaDetector/ADAravis
Prev: Re: read RVB and VAL don't match when moving smarAct motors without encoders Kevin Peterson via Tech-talk
Next: either_ip related issue Smith, Martin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: read RVB and VAL don't match when moving smarAct motors without encoders Peterson, Kevin M. via Tech-talk
