1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: either_ip related issue
From: "Smith, Martin via Tech-talk" <[email protected]>
Date: Mon, 16 Nov 2020 11:47:50 +0000
Has anyone ever seen this problem before?
I have an AB ControlLogix PLC that I'm communicating with and it seems that this tag name
(and at least 2 more) are incorrectly being seen by the Linux soft IOC record as the year 2018.
The record in the IOC is an ai record set to 10 second scan rate because I have also been
noticing record values being incorrect using the INP field with S 10.
The IOC is running EPICS 3.14.12.5 with ether_ip 2-26
When I set the EIP_verbosity(10) I can find the tag name here which correctly gives me the
year 2020.
MultiRequest reply at offset 0x3E: Response #3 (EPICS_PLC_TIME_YEAR):
MR_Response:
    USINT service         = 0xCC (Response to CIP_ReadData)
    USINT reserved        = 0x00
    USINT status          = 0x00 (Ok)
    USINT ext. stat. size = 0
Data (1 elements): DINT 2020
But running this command I get 2018 which is also what I see on the IOC.
ether_ip_test -i <ip address> EPICS_PLC_TIME_YEAR
Tag 'EPICS_PLC_TIME_YEAR'
DINT 2018
1 test runs, 0.0276279 seconds -> 27.627945 ms / tag
Also the IOC record reports 2018.
Marty
Prev: New releases of ADGenICam and ADAravis Mark Rivers via Tech-talk
Next: NFSv4 and shared data directories Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
