Subject: Re: read RVB and VAL don't match when moving smarAct motors without encoders
From: Kevin Peterson via Tech-talk <[email protected]>
To: Juliane Reinhardt <[email protected]>, "Rivers, Mark L." <[email protected]>
Date: Fri, 13 Nov 2020 16:49:22 -0600
Juliane,
Having an open-loop move command is helpful, though I don't know how to map steps + frequency to EGU, but not sufficient to make open-loop axes work well with the motor driver. The motor record expects a feedback position to be updated by the driver.
It would be fairly easy to write streamDevice support to allow sending the open-loop move command from EPICS. I don't know how well this would work if some of the axes on the MCS controller needed open-loop moves and others work correctly with the EPICS motor driver.
Kevin
On 11/13/20 4:03 PM, Juliane Reinhardt wrote:
Hi Kevin,
we found the ASCII command to move a motor that does not have an encoder
in the SmarAct manual, p70:
Example:
MST0,100,4095,100
Performs 100 steps at full amplitude and 100 Hz on channel 0.
Is that information enough to implement that in the MCS driver for
EPICS? Would you be able to modify the driver or can you assist me in
doing that? I have not experience yet in writing the actual EPICS
drivers. I assume, we would add this option to the move command
beginning in line 502 of the current smarActMCSMotorDriver.cpp
Another naive idea would be to move the motor using the hardware's
step-count register? I tried moving using caput $motor.RVAL but that
doesn't work either. Any options to setup an RDBL Link to read positions
from or does that only over complicate things and we should rather have
the driver adapted?
Thanks for your help,
Juliane
read RVB and VAL don't match when moving smarAct motors without encoders Juliane Reinhardt via Tech-talk
Re: read RVB and VAL don't match when moving smarAct motors without encoders Peterson, Kevin M. via Tech-talk
Re: read RVB and VAL don't match when moving smarAct motors without encoders Juliane Reinhardt via Tech-talk
Re: read RVB and VAL don't match when moving smarAct motors without encoders Mark Rivers via Tech-talk
Re: read RVB and VAL don't match when moving smarAct motors without encoders Kevin Peterson via Tech-talk
Prev: Re: Connection to PVA server fails despite server Wlodek, Jakub via Tech-talk
Next: New releases of ADGenICam and ADAravis Mark Rivers via Tech-talk
Prev: Re: read RVB and VAL don't match when moving smarAct motors without encoders Juliane Reinhardt via Tech-talk
Next: Re: read RVB and VAL don't match when moving smarAct motors without encoders Peterson, Kevin M. via Tech-talk
