Subject: Re: read RVB and VAL don't match when moving smarAct motors without encoders
From: Kevin Peterson via Tech-talk <[email protected]>
To: Juliane Reinhardt <[email protected]>, Mark Rivers <[email protected]>
Date: Thu, 12 Nov 2020 17:27:17 -0600
The controller is returning an error for both of the position query commands used by the driver:
2020/11/12 15:11:03.905 192.168.168.200:5000 write 5\
:GP1\\n\
2020/11/12 15:11:03.908 192.168.168.200:5000 read 8\
:E1,129\\n\
2020/11/12 15:11:03.912 192.168.168.200:5000 write 5\
:GA1\\n\
2020/11/12 15:11:03.915 192.168.168.200:5000 read 8\
:E1,129\\n\
The sensor type that is returned is 1:
:GST1\\n\
2020/11/12 15:11:03.912 192.168.168.200:5000 read 7\
:ST1,1\\n\
A sensor type of 1 is a "linear positioner with nano sensor", according to the MCS RS-232 interface documentation.
I don't see any commands that would query a theoretical position of an axis that doesn't have an encoder. If SmarAct can provide that information, we can modify the driver to use it.
Kevin
On 11/12/20 5:16 PM, Juliane Reinhardt wrote:
Hi Mark,
does the output in the txt attachment make more sense to you?
Cheers,
Juliane
Re: read RVB and VAL don't match when moving smarAct motors without encoders Juliane Reinhardt via Tech-talk
Re: read RVB and VAL don't match when moving smarAct motors without encoders Peterson, Kevin M. via Tech-talk
Re: read RVB and VAL don't match when moving smarAct motors without encoders Mark Rivers via Tech-talk
Prev: Re: read RVB and VAL don't match when moving smarAct motors without encoders Juliane Reinhardt via Tech-talk
Next: Re: read RVB and VAL don't match when moving smarAct motors without encoders Juliane Reinhardt via Tech-talk
