1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: read RVB and VAL don't match when moving smarAct motors without encoders
From: Juliane Reinhardt via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, "Peterson, Kevin M." <[email protected]>
Date: Thu, 12 Nov 2020 13:29:26 -0800
Hi Mark,
thanks. I added the lines and tried to move the motors. I got the following error log:
2020/11/12 11:41:07.542 asynMotorController:writeFloat64 error, status=3 axis=1, function=1, value=100000.000000 2020/11/12 11:41:07.542 devMotorAsyn::asynCallback: cosmic:OSA_Y pasyn{Float64,Int32}->write returned 2020/11/12 11:41:07.542 192.168.168.200:5000 write 5
I found a similar issue in an older TechTalk request, where you explained that:
This message is printed by the asynMotorController base class when it called the driver with a float64 value and the driver returned an error.
However, I don't really know how to prevent the driver from returning that error. We are already in contact with smarAct but it seems like an EPICS related error, isn't it?
Best,
Juliane
On 11/12/20 11:13, Mark Rivers wrote:
Hi Juliane,
Is there a  way to get for feedback in EPICS, like a debug mode?
Yes, you can see the complete communications data stream by enabling asynTraceIODriver for the underlying asyn port in your startup script.
You can modify this example startup script:
motor/modules/motorSmarAct/iocs/smarActIOC/iocBoot/iocSmarAct/smaractmcs.iocsh
to add these lines:
drvAsynIPPortConfigure("MCS_ETH","192.168.1.17:2102",0,0,0)
asynSetTraceIOMask("MCS_ETH", 0, "ESCAPE")
asynSetTraceMask("MCS_ETH", 0, "ERROR|DRIVER")
That will print all of the TCP communication between the IOC and the MCS controller.
From: Tech-talk <[email protected]> on behalf of Juliane Reinhardt via Tech-talk <[email protected]>
Sent: Thursday, November 12, 2020 12:17 PM
To: Peterson, Kevin M.; [email protected]
Hi Kevin,
thanks for your reply. I'm not sure what you mean by GST, GA or GP
commands. However, we tried to communicate with the smarAct motors via
the vendor software and did not get very informative feedback. (Same
return value no matter what motor/controller we were using) Is there a
Best,
Juliane
On 11/11/20 16:05, Peterson, Kevin M. wrote:
Juliane,
How does the MCS controller respond to the GST, GA and GP commands for
an axis without an encoder?  It should be possible to send them using an
asyn record or a terminal in the vendor software.
The MCS driver assumes every axis will have a sensor and sets the motor
record's problem bit if the GST command returns an error.
Kevin
On 11/11/20 4:14 PM, Juliane Reinhardt via Tech-talk wrote:
Dear EPICS team,
I have recently been setting up smarAct MCS controllers for a couple of
smarAct motors, some of them have encoders and some don't. The 2 motors
that don't have encoders don't move although they are connected properly
(I assume). When I do "caput motor.VAL 0.5" I get the feedback for old
and new VAL and when I check with "caget motor.VAL" it matches. However,
the actual "caget motor.RBV" does not change accordingly and the motor
did not move.
What is required to move motors without an encoder in this case?
Juliane
Juliane Reinhardt, PhD
Project Scientist | ALS Computing Group
Blg. 15-337E | phone: 510-486-4313
[email protected]
Lawrence Berkeley National Lab
[email protected]
Re: read RVB and VAL don't match when moving smarAct motors without encoders Mark Rivers via Tech-talk
read RVB and VAL don't match when moving smarAct motors without encoders Juliane Reinhardt via Tech-talk
Re: read RVB and VAL don't match when moving smarAct motors without encoders Peterson, Kevin M. via Tech-talk
Re: read RVB and VAL don't match when moving smarAct motors without encoders Juliane Reinhardt via Tech-talk
Prev: Re: read RVB and VAL don't match when moving smarAct motors without encoders Mark Rivers via Tech-talk
Next: Re: read RVB and VAL don't match when moving smarAct motors without encoders Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
