1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: EPICS driver for Xilinx ZYNQ ultrascale FPGA firmware PL register read write
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Kunjir, Shriraj" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 7 Dec 2020 10:45:50 -0800
On 12/7/20 8:24 AM, Kunjir, Shriraj via Tech-talk wrote:
> Hello,
> We have a design based on Xilinx ZYNQ Ultrascale plus FPGA. We have compiled EPICS base on the PS Linux side of the FPGA by following the tips mentioned here https://epics.anl.gov/tech-talk/2016/msg00632.php <https://epics.anl.gov/tech-talk/2016/msg00632.php>. We can read/write firmware PL side registers using busybox devmem from PS Linux and we are developing an application to read/write firmware PL registers from EPICS. Essentially, we are looking to run IOC on the Linux side of the FPGA. Are there any EPICS drivers that can do this ?
> Can devlib2 do this ?
At present, only if your FPGA logic appears to Linux as a PCI device.
Adding support for platform devices (or other non-discoverable)
device should be possible, but hasn't yet been done.
> Below is C code to read and write firmware registers (if not using busybox devmem)
> *C code to read firmware registers from Linux – *
> /#include <stdio.h>/
> /#include <stdlib.h>/
> /#include <unistd.h>/
> /#include <sys/mman.h>/
> /#include <fcntl.h>/
> /void usage(char *prog)/
> /                printf("usage: %s ADDR\n",prog);/
> /                printf("\n");/
> /                printf("ADDR may be specified as hex values\n");/
> /int main(int argc, char *argv[])/
> /                int fd;/
> /                void *ptr;/
> /                unsigned addr, page_addr, page_offset;/
> /                unsigned page_size=sysconf(_SC_PAGESIZE);/
> /                if(argc!=2) {/
> /                                usage(argv[0]);/
> /                                exit(-1);/
> /                fd=open("/dev/mem",O_RDONLY);/
> /                if(fd<1) {/
> /                                perror(argv[0]);/
> /                                exit(-1);/
> /                addr=strtoul(argv[1],NULL,0);/
> /                page_addr=(addr & ~(page_size-1));/
> /                page_offset=addr-page_addr;/
> /                ptr=mmap(NULL,page_size,PROT_READ,MAP_SHARED,fd,(addr & ~(page_size-1)));/
> /                if((int)ptr==-1) {/
> /                                perror(argv[0]);/
> /                                exit(-1);/
> /                printf("0x%08x\n",*((unsigned *)(ptr+page_offset)));/
> /                return 0;/
> *C code to write firmware registers from Linux  - *
> /                printf("usage: %s ADDR VAL\n",prog);/
> /                printf("\n");/
> /                printf("ADDR and VAL may be specified as hex values\n");/
> /                int fd;/
> /                void *ptr;/
> /                unsigned val;/
> /                fd=open("/dev/mem",O_RDWR);/
> /                if(fd<1) {/
> /                                perror(argv[0]);/
> /                                exit(-1);/
> /                if(argc!=3) {/
> /                                usage(argv[0]);/
> /                                exit(-1);/
> /                val=strtoul(argv[2],NULL,0);/
> /                ptr=mmap(NULL,page_size,PROT_READ|PROT_WRITE,MAP_SHARED,fd,(addr & ~(page_size-1)));/
> /                                perror(argv[0]);/
> /                                exit(-1);/
> /                *((unsigned *)(ptr+page_offset))=val;/
> /                return 0;/
> *Raj K*
> Facility for Rare Isotope Beams
RE: EPICS driver for Xilinx ZYNQ ultrascale FPGA firmware PL register read write Kunjir, Shriraj via Tech-talk
Prev: Re: How do I pass a macro to a CSS Phoebus screen at startup from the command line Pietryla, Tony via Tech-talk
Next: RE: EPICS driver for Xilinx ZYNQ ultrascale FPGA firmware PL register read write Kunjir, Shriraj via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: EPICS driver for Xilinx ZYNQ ultrascale FPGA firmware PL register read write Kunjir, Shriraj via Tech-talk
